Stage 3 cams - Mustang Evolution
Old 05-17-2012, 05:04 PM   #1
Sonicblue11's Avatar
Stage 3 cams
I am just about ready to pull my motor out of my old stang and I am sending the block out to get bored and going with trick flow heads,diamond pistons and I really want stage 3 cams but my friend keeps telling me it I get them I will lose 30-40rwhp? Is this true and will it really make a difference since the motor will be stroked??!!
Sonicblue11 is offline   Reply With Quote
Old 05-17-2012, 05:33 PM   #2
Re: Stage 3 cams
Normally when you get stage 3 cams you gain rwhp and rwtq instead of lose it... I don't know why he would tell you that.
Old 05-17-2012, 05:40 PM   #3
Idk why he did and yeah I thought you would gain rwhp it makes sense
Old 05-17-2012, 05:42 PM   #4
Stang.racr's Avatar
You wouldn't loose power on top end. That is a big cam and drivability will be affected. You would loose some off idle torque due to the fact the power range is somewhere in the 3k to 6.5k. But you would gain hp as long as the heads and intake flowed good.
having a fine car that is slow is like having a hot girlfriend that won't put out!
Stang.racr is offline   Reply With Quote
Old 05-17-2012, 05:54 PM   #5
Yeah I'm Deffinatly getting stage 3!! I can't wait until I get new heads man
Old 05-17-2012, 07:57 PM   #6
t0t4lbl4ck0ut's Avatar
Make sure you don't drop those cams in until you get those trick flows cause you will have to much lift for the clearance you have with the stock heads. Trick flows allow the biggest can you can get for the 2v because of the different placement of the valves.
t0t4lbl4ck0ut is offline   Reply With Quote
Old 05-17-2012, 08:35 PM   #7
Yeah I know, I didn't start the motor project yett but I need to find a machine shop that will bore my cylinders 30 over first
09:54 PM
