The ultimate 2v engine! - Mustang Evolution
Old 05-17-2012, 10:47 PM   #1
FORDGT14's Avatar
Exclamation The ultimate 2v engine!
I will be dumping a HUGE amount of money into my spare engine I have on my engine stand very soon, it's been waiting for quite sometime, and it's finally time to start. I want you guys to help me build the ultimate 2V 4.6L by helping create a list of parts I could buy to build an extremely powerful N/A 2V engine. Of course I will be slapping a Kenne Bell on it eventually, but I want to get as much power as possible being N/A before I do.
If possible, list the parts with prices.
Thanks guys.
FORDGT14 is offline   Reply With Quote
Old 05-18-2012, 12:08 AM   #2
t0t4lbl4ck0ut's Avatar
You can't really do that unless you plan on rebuilding it at some point. In order to get as much as you can N/A you have to have high compression and forged or not your motor will go FAST on FI with that high of compression.
t0t4lbl4ck0ut is offline   Reply With Quote
Old 05-18-2012, 12:47 AM   #3
Arron's racecar's Avatar
Region: Nevada
This is true! But if you were to stay with a lower c/r then you would be ok but dont try to do both go max N/A or plan for boost. My power engine build is going to consist of a forged 2v short block with 44cc ported trick flow twisted wedge heads with matching manifold and pelenum and stage 3 blower cams and then an intercooled vortech V3 supercharger kit with 40lbs injectors. I'm looking to hit 500-600 rwhp and similar TQ.
2004 GT current mods : CAI, BBK Short throw shifter TB and UDPs, SCT x3/SF3 with BAMA Perfomance tunes Roush body kit, roush side skirt exhaust and paint.
Arron's racecar is offline   Reply With Quote
Old 05-18-2012, 01:07 AM   #4
Mines prettying the same except I'm going a 5.0 big bore and skipping the manifold and going with the kenne bell 2.6 and 60 lbs injectors. That kenne bell is good for nearly 30 psi and I plan on running about 25 lbs with meth on track runs. That should be pushing around 800hp or so. I don't plan on running that much boost all the time though. My car is cammed now with stage 2 comp cam custom grinds for boost and I still run 13.2 1/4s
Old 05-18-2012, 01:07 AM   #5
Nashgizam's Avatar
Region: Nebraska
Jake you would b the first to reply to this lol
Nashgizam is offline   Reply With Quote
Old 05-18-2012, 01:07 AM   #6
Lol haha oh yes
Old 05-18-2012, 03:06 AM   #7
FORDGT14's Avatar
Re: The ultimate 2v engine!
What do you mean rebuilding it at some point? Thats what I'm gona be doing to the spare engine, forged internals and all, with the trickflow top end most likely, so I dont really get what your saying?
Old 05-18-2012, 03:40 AM   #8
DaBluedude's Avatar
You can build a na engine and then decide to throw a blower on it. The principals just don't mesh. Your looking at 11-13 comp on a na street build and 8-9.5 on a blower build. Honestly I don't know why you want to do the 2v. I know it works but a 4v will go a long ways. And for the cost of the tw heads u could get the heads and drop them on a forged shortblock. I see no reason why a 11.6 forged compression 4v couldn't make 425hp. Cams, porting and a valve job and 450 would be feasable.
2003 Mach 1
Old 05-18-2012, 03:48 AM   #9
FORDGT14's Avatar
I'll stick with the 2V, I've already got it here and I'd like to see how far I can get with one, I wana keep it a "Gt" and if I went 4V I'd need the engine, tranny ect. right? It's just more convenient for me to stay 2V...
And as for the trickflow setup, I can just forge the bottom end, and then buy the trickflow setup, and that alone would make 330 rwhp. At that point, I could just throw an S/C on it right? But how much boost can you run with a forged bottom end on a 2V?
Old 05-18-2012, 03:50 AM   #10
It cost more then that to do a 4v swap unless you buy a salvage block and they won't be the 03-04 4v heads and it's a royal pain in the *** to do the swap. Especially if they aren't matching blocks since you'd have to rig your accessories to work. Plus trick flows out flow 4v heads with a stage 1 porting. They are about a billion times less of a pain and do just as well. Plus on top of that trick flows allow for the BIGGEST cams you can find without any fly cutting of the pistons.
Old 05-18-2012, 03:53 AM   #11
FORDGT14's Avatar
+1
I like my little 2V..and the trickflows make some impressive dyno numbers over stock
---------- Post added at 03:53 AM ---------- Previous post was at 03:52 AM ----------
And yeah, it would be easier to build the engine I already have on the stand and my car is already setup for it. WAY easier lol
Old 05-18-2012, 04:00 AM   #12
Plus it's about a billion times more impressive to build a sick 2v over a 4v. That's just too easy to do.
---------- Post added at 08:55 AM ---------- Previous post was at 08:54 AM ----------
The block will work no matter what heads it is but it's just a mess getting everything to match up and work properly.
---------- Post added at 09:00 AM ---------- Previous post was at 08:55 AM ----------
A forged bottom end will handle whatever you put to it as long as you have the right fasteners and a low enough compression. Dont skip out on the bolts for your rods or anything ARP is the way to go EVERYWHERE. Your gonna want around 8.5 cr for a large amount of boost.
Old 05-18-2012, 04:02 AM   #13
FORDGT14's Avatar
Hell yeah! I've never seen a fully built 2V in person, I'd be the only one around here with it.
And what boost would you recommend with this setup? And what kid of power should I expect?
Old 05-18-2012, 04:17 AM   #14
Well I have no knowledge of centrifugal style superchargers. I know a 2.1 kenne bell twin screw style supercharger will make at max boost of 20 psi which is more then they recommend to run will make 717 hp at the engine with ported pi heads and injectors at 9.0:1 cr. The 2.6 will do upwards of 30 psi and stay efficient within that range too and it will make alot more then 717hp lol
---------- Post added at 09:16 AM ---------- Previous post was at 09:13 AM ----------
I'll be the only built mustang where I live when mines done. And the only one that makes anywhere near that power too.
---------- Post added at 09:17 AM ---------- Previous post was at 09:16 AM ----------
If you run massive amounts of boost with the supercharger youll need to run some form of cooling like methanol injection or what not. It's ALOT of heat.
Old 05-18-2012, 04:27 AM   #15
FORDGT14's Avatar
****, if it will make 717 at the engine with the ported pi heads than it will be a rocket ship with the trickflows...gona be scary seems how my cars a vert lol is there a way to reinforce these verts without adding too much weight to them?
And yeah, I figured that.
Old 05-18-2012, 04:37 AM   #16
Subframe connectors. Get the maximum motorsports ones. The full Length ones are the ones you want
Old 05-18-2012, 04:40 AM   #17
That's how stiff it makes it with them on there. Idk about the vert since its missing a roof lol that's 3 wheels off the ground from the front.
ID:	50838   Click image for larger version
Old 05-18-2012, 07:25 AM   #18
Mzilla's Avatar
Find yourself a 96-98 teksid cobra short block and cobra crank get some good h beam rods and some 6cc dished forged pistons. These blocks handle a little over a 1000hp with all ARP 2000 studs thru out. Change out the stock PI intake to and an edelbrock or trick flow and some good stg2 or 3 cams. You then can add some some good stage 3 ported PI heads or trick flows. Dont forget to add a good billet gear oil pump. Then add 20 pounds of boost this combo will net 600-650rwhp on 93.. I would recommend running 60 or 80 lbs injectors. I also might add you need an entire new fuel system to achieve these numbers. I have an 03-04 cobra tank with twin Ford GT pumps and a Kenne Bell boost a pump. I also have a modified dual FPDM with 8 gauge wiring. I have over 2k In the fuel system alone. I'm also adding a Snow Performance stage 3 meth/water kit. You really need to figure out your budget because all these parts dont include a bunch of tuning or dyno time to dial it all in. Hope this helps.
Mzilla is offline   Reply With Quote
Old 05-18-2012, 11:01 AM   #19
Mmustang01's Avatar
True
01 gt
Procharger d1
Mmr long block
480 rwhp 450 # of torque
Mmustang01 is offline   Reply With Quote
Old 05-18-2012, 03:58 PM   #20
CodyNelson's Avatar
Region: West Virgina
Your gonna want bigger injectors than that to get in that power level
Old 05-18-2012, 05:47 PM   #21
Mmustang01's Avatar
That's right at least 60 #
01 gt
Procharger d1
Mmr long block
Old 05-18-2012, 06:20 PM   #22
Region: Nevada
60 eh... duely noted thanks
Old 05-18-2012, 09:20 PM   #23
Mmustang01's Avatar
01 gt
Procharger d1
Mmr long block
Old 05-27-2012, 10:42 PM   #24
FORDGT14's Avatar
Does anyone know if they sell a trickflow longblock? Like already assembled bottom end and heads too? Just basically bolt my timing, valve covers, and alternater ect. on and drop the engine in? Give me a link if possible. Thanks
Old 05-27-2012, 11:01 PM   #25
http://www.modularmustangracing.com/
Look In their long block section. Amazing quality stuff.
Old 05-28-2012, 01:50 PM   #26
FORDGT14's Avatar
Wow. They have some damn good deals. Which one would you go with?
Old 05-28-2012, 06:30 PM   #27
I'm doing a forged big bore 5.0 without a stroker cranks with ported trickflow heads
Old 05-28-2012, 06:36 PM   #28
FORDGT14's Avatar
How much is that gona run you?
Old 05-28-2012, 09:33 PM   #29
I'm just working on a bare block. I'm not buying a long block or anything. I'm actually worried about my rear end at the moment. If you havent built yours yet I'd suggest it. I snapped an axle and tore up my ring gear and diff with full bolt ons and cams.
Old 05-28-2012, 09:37 PM   #30
Lorraine's driver
ab_mach1's Avatar
+1 At least stay away from drag radials until you build up your diff.
Instagram: @ab_mach1
Old 05-28-2012, 09:43 PM   #31
Venomouz831's Avatar
Wait sorry haven't read the whole conversation but I'm going to put some 305's on my car is tht bad?
)02 Gt, Founder of WE2G
Old 05-28-2012, 09:58 PM   #32
Lorraine's driver
ab_mach1's Avatar
No, I think would great and look good! I was saying that if your building an engine to produce HP like FORDGT14 is doing, prolly gonna need to build up the rear diff. Really, might need to build up the tranny too.
Old 05-28-2012, 10:20 PM   #33
Oh ok solid
Old 05-28-2012, 10:24 PM   #34
Yea take it from me. I blew up my rear end with just bolt ons and cams.
Old 05-28-2012, 10:29 PM   #35
BigB227's Avatar
Don't want to sound like an idiot but what all do you have to do to build up your rear end??
BigB227 is offline   Reply With Quote
08:49 PM
