Head Swap - Mustang Evolution
Old 05-18-2012, 09:34 AM   #1
Randl114's Avatar
Head Swap
Starting to get a rattle from the top end so I was thinking about the pi head swap. My car is a 96 GT. Anybody that has done this, could you tell me a parts list. Obviously heads and intake, but what else might I run into. Thanks for the help.
Your enemy is doing what you can not. When you meet he WILL defeat you.
Randl114 is offline   Reply With Quote
Old 05-18-2012, 09:53 AM   #2
Eturner's Avatar
If you got the extra cash, I would do some aftermarket heads for a PI motor, like from TrickFlow!.. You will get some huge gains then!..
As far as doing the actual swap, unfortunatly I can't help you much there!..
Old 05-18-2012, 01:18 PM   #3
t0t4lbl4ck0ut's Avatar
I think AM has a kit for it but not sure. +1 on the buying aftermarket heads if you have the cash
t0t4lbl4ck0ut is offline   Reply With Quote
Old 06-10-2012, 06:15 PM   #4
LAS97GT's Avatar
Hello E, good to see you on the forum, but those TF are expensive. Heard about Patriot heads only they don't shift the Valve flow to opposite sides, but they do change compression to 44cc. Stock is 51 I think. What you think? I will spend the rest of the year researching, so take your time.
---Las97GT
Old 06-10-2012, 06:24 PM   #5
Mile high JDF's Avatar
I've heard that those Patriot heads have valve seal issues. I don't have personal experience wit them but that's what I've heard about them.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 06-10-2012, 07:41 PM   #6
Eturner's Avatar
Ya I've heard both good and bad about Patriot, and mostly good about Trick Flow!..
---------- Post added at 07:41 PM ---------- Previous post was at 07:39 PM ----------
True but you also tend to get what you pay for!.. But do let me know what you find!..
Old 06-10-2012, 07:46 PM   #7
I haven heard anything bad about Trick Flow yet, but I havent done much research. I was always told that the patriots are almost the equivalent of a P&P set of PI heads, minus the decreased combustion chamber.
Old 06-10-2012, 07:49 PM   #8
Eturner's Avatar
Ya I've only heard like one bad thing about Trick Flow myself!...
Old 06-10-2012, 07:58 PM   #9
What was that?
Old 06-10-2012, 08:21 PM   #10
Eturner's Avatar
What was that?
I don't remember exactly because it's been a while!.. But it was something about how it fit!.. But like I said it's been awhile and it was only once!...
Old 06-10-2012, 08:54 PM   #11
Awesome! I plan on getting those heads eventually seeing as there's no other good set out there
02:46 AM
