Is this bad? - Mustang Evolution
Old 05-20-2012, 12:52 AM   #1
Lorraine's driver
ab_mach1's Avatar
Is this bad?
Ok, changing spark plugs. The one closest to the driver has residue all within spark plug shoot and around the outside. Should I be worried about this? Pics...
Instagram: @ab_mach1
Old 05-20-2012, 02:12 AM   #2
Lorraine's driver
ab_mach1's Avatar
Finished the job and started it up. Its running worse and actually showing the service engine soon light. It was running poorly before, but now it's worse. I don't have a tuner so I'll need to got to O'Reilly Auto to find out if it's related to the spark plug change. Who knows.
Old 05-20-2012, 08:06 AM   #3
imhooked's Avatar
Re: Is this bad?
if u still need help can call me... will talk 2 u and try 2 help if i can... i'm free till i head off for golf, and my cell is 845-797-1864
joe
imhooked is offline   Reply With Quote
Old 05-20-2012, 08:20 AM   #4
Lorraine's driver
ab_mach1's Avatar
joe
I'm fixin to find out what codes it has. Hopefully it's just a bad coil on plug. If not, I'll be needing help for sure. Has any of your plug sleeves looked like the pics above? The passenger side, closest to the passenger looked almost the same. Maybe just a little less of the residue seen in the pic. The plug tip didn't look any worse than any of the other plugs. Just all the powdery yellowish residue.
Old 05-20-2012, 09:41 AM   #5
Lorraine's driver
ab_mach1's Avatar
The OBD2 reader said "ignition coil D". Which cylinder is that?
Old 05-20-2012, 10:38 AM   #6
Lorraine's driver
ab_mach1's Avatar
Okay, figured out this is cylinder #4. I swapped the COP to another spot and the problem went away. I think I must have had a bad connection or the boot wasn't secure. Anyway Yay me!
Old 05-20-2012, 08:20 PM   #7
imhooked's Avatar
Re: Is this bad?
oh, just asked question you answered here over on my thread! anyway, glad you got it... and i don't know what the coloration was from. my guess would be oil, or some other chemical been sprayed on or spilled back there maybe and never cleaned up
Old 05-20-2012, 08:25 PM   #8
Lorraine's driver
ab_mach1's Avatar
I know we're jottin on two threads ha! You think shmoots could be from the dealer cleaning up the engine before selling it?
Old 05-20-2012, 10:01 PM   #9
2000Blackgt's Avatar
Re: Is this bad?
Just letting you know that corrosion on the plug is water that dried inside the spark plug hole.
2000Blackgt is offline   Reply With Quote
Old 05-20-2012, 10:04 PM   #10
Lorraine's driver
ab_mach1's Avatar
Thanks man. I'm hoping that was from the dealer or previous owner cleaning the engine before selling it. The gasket to the COP cover looks good, but would prolly not hold out water from pressure sprayer.
Old 05-20-2012, 11:06 PM   #11
No problem
Old 05-20-2012, 11:23 PM   #12
02PONY's Avatar
The yellow stuff just looks like dried up dialectic grease
02PONY is offline   Reply With Quote
Old 05-20-2012, 11:26 PM   #13
Caused by water 😞
Old 05-20-2012, 11:38 PM   #14
02PONY's Avatar
Tep
04:53 AM
