fuel injectors for S/C - Mustang Evolution
Old 05-21-2012, 01:18 PM   #1
I have a 2000 gt that has been rebuilt with forged crank and CNC ported heads and etc. I have a SCT MAF, and I was told I bought a 03 cobra fuel pump but it was a single hat pump setup. Im planning on getting a BAP along with that too. Long tubes, 70 mm throttle bottle and all you basic bolts ons with a tuner etc. Im planning on getting a vortec supercharger running 9-11 of boast so what size injectors would be good? I was look at 60 something lbs/hr...whatcha think?
southernstang00 is offline   Reply With Quote
Old 05-21-2012, 01:45 PM   #2
Really going to depend on your car and what pump you have... With a single pump it might be hard to keep up with those larger injectors
Old 05-21-2012, 01:49 PM   #3
Re: fuel injectors for S/C
even with a BAP added?what injectors you think would work ?
Old 05-21-2012, 02:15 PM   #4
Rm360's Avatar
For the set up you got going I would run the 42lb injectors
Old 05-21-2012, 02:21 PM   #5
What pump is it?
Old 05-21-2012, 02:26 PM   #6
Yea I was told that too but I dont want to buy them and they arent enough...ya know.
Far as the pump, it said 03-04 cobra on the ford box but ive found out that they were a dual hat system instead of just one pump.
Old 05-21-2012, 03:03 PM   #7
Rm360's Avatar
With the cobra pump a boost a pump the 42 lb injectors can support up to 19 lbs of boost and close to 600 rwhp
Old 05-21-2012, 10:30 PM   #8
gotcha....im going with a vortec v-3
Old 05-22-2012, 04:57 AM   #9
Mzilla's Avatar
My old set up was almost identical to yours. I was running single Ford GT supercar pump with BAP and 60lb injectors. I was running no more than 14 lbs of boost. The 60lbs are perfect.
Mzilla is offline   Reply With Quote
Old 05-22-2012, 06:35 AM   #10
im not sure if it is the same pump as your but it did say 03 cobra on the box...unless its a new style and only has one pump I dunno...WOuld 60 be over kill...
Old 05-22-2012, 08:11 AM   #11
Mzilla's Avatar
I reused my factory Mustang GT fuel hat and installed a single Ford Gt pump with BAP. Get the 60lb injectors you are better to have too much injector then not enough plus if you ever want to increase power they will be there. You will likely only use 50% or less duty cycle. I am now running an 03-04 cobra tank with twin Ford GT pumps.
Old 05-22-2012, 09:08 AM   #12
Mmustang01's Avatar
+1
01 gt
Procharger d1
Mmr long block
480 rwhp 450 # of torque
Mmustang01 is offline   Reply With Quote
Old 05-22-2012, 12:56 PM   #13
gotcha, im def going with that and like your idea....I rather have too much injector then not enough. Are putting the vortec supercharger kit on a pain or is it something that can be done in like a weekend?
05:20 PM
