Bore 30 over - Mustang Evolution
Old 05-21-2012, 02:45 PM   #1
Sonicblue11's Avatar
Bore 30 over
What would be better..if I bore it 30 over or 40 over!?? I not too sure
Sonicblue11 is offline   Reply With Quote
Old 05-21-2012, 03:08 PM   #2
Rm360's Avatar
What plans do you have for the engine?
Old 05-21-2012, 03:24 PM   #3
tc x 4's Avatar
Less is always better. You only have so much metal to work with and you never know when you'll have to do it again.
Old 05-21-2012, 03:42 PM   #4
I plan on boring it 30 over with a new crank and getting diamond pistons with h beam rods and trick flow twisted wedge heads with trick flow intake manifold and yeah I think I'm going to do 30
Old 05-21-2012, 03:47 PM   #5
Rm360's Avatar
Did you plan on forced induction at all?
Old 05-21-2012, 03:52 PM   #6
No not really I need to know what I need first maybe you guys can help me out haha when you say forced induction what do you mean by it? Haha this motor stuff is still all new to me
Old 05-21-2012, 03:56 PM   #7
Rm360's Avatar
The 4.6 is a bomb waiting to blow if you do forced induction with a over bore, the cylinder walls in a 4.6 are thin already most people I know that do keep it NA with an over bore only go .20 over to keep it safe, either way IMO its not worth spending all that money for a 20 hp gain
---------- Post added at 04:56 PM ---------- Previous post was at 04:55 PM ----------
Forced induction like a vortech or kenne bell supercharger
Old 05-21-2012, 04:06 PM   #8
My friend went 30 over and his motor is just fine
Old 05-21-2012, 05:10 PM   #9
And yeah I want to supercharge it but I can't with my stock motor so that's why I'm going to bore it
Old 05-21-2012, 05:19 PM   #10
Rm360's Avatar
What ? If you want to supercharge it don't bore it you will blow the motor up!
---------- Post added at 06:19 PM ---------- Previous post was at 06:15 PM ----------
I have a kenne bell running 10 lbs on a stock motor with no problems at all !
Old 05-21-2012, 05:30 PM   #11
Yeah but I want more than 10 Ibs of boost though
Old 05-21-2012, 05:38 PM   #12
Rm360's Avatar
Even more so to not bore it , the 4.6 loves boost the more boost you run the more fuel you need which creates more combustion in the chamber if you bore the block you are taking material away from the cylinder wall , you are making the block weaker by doing this!
Old 05-21-2012, 05:49 PM   #13
Yeah but how do people get like 400rwhp by doing motor work then?
Old 05-21-2012, 05:52 PM   #14
Stockish302's Avatar
Dont bore it out if you want to go with boost. If you want more power just raise the boost. I sold a mmr 1000 shortblock stock bore and stroke and the guy is running 25psi making 850+whp with a very conservative tune and stock 2v heads with a mild port.
BBK cai, 96 tbird maf housing, BBK 70mm TB, TFS intake manifold, BBK shortys, bassani off road X pipe, Flowmasters with turndowns
If any one is willing to donate parts to the Make Joe's Mustang Faster that Corvettes Foundation, donations will be gladly appreciated
Stockish302 is offline   Reply With Quote
Old 05-21-2012, 05:56 PM   #15
Gotcha well what would the benefit of boring it do? My friend has a bullit and he is bored 30 over and has diamond pistons and is pushing 380whp
Old 05-21-2012, 05:56 PM   #16
Rm360's Avatar
This is how you make more power! 400 rwhp with a supercharger is easy to do
Old 05-21-2012, 05:58 PM   #17
I also wanted to do heads and cams as well
Old 05-21-2012, 06:03 PM   #18
Rm360's Avatar
Even eaiser then ! All you need is the forged bottom end and it will handle anything you can throw at it , the overbore give you more cubic inches changing the 281 to roughly a 302 but it doesn't have any benifit in a FI application
Old 05-21-2012, 06:11 PM   #19
Gotcha so I could just throw on heads and cams and supercharger and I'll be good? My friend with the bullit has 30 over and he said to make it a 5.0 he needed the crank but he didn't have the money for the crank so he is just 30 over with pistons
---------- Post added at 06:11 PM ---------- Previous post was at 06:11 PM ----------
And I do appreciate the help man!!! Thanks a lot!!
Old 05-21-2012, 06:16 PM   #20
Rm360's Avatar
With a set of trick flow heads, custom blower cams , and a supercharger, and a good fuel system set up you will be at 500 rwhp with no problem and be able to run it all day , and you're welcome just don't want you to spend all that money and your engine go boom !!! LOL !!!!
Old 05-21-2012, 06:21 PM   #21
Haha I hear ya man I don't want to spend alot either haha I'm only 19 making 14.50 and hour but would I need to change the crank or anything? See the thing is I have 2 motors, the one in my current GT and my totaled GT which I just started to pull the motor so if it was you and you didn't want to spend a lot of money what would you do? Haha
Old 05-21-2012, 06:22 PM   #22
This is the motor I'm pulling
Old 05-21-2012, 06:36 PM   #23
Rm360's Avatar
You have to decide where you want to go with your build the FI route is more costly due to all the upgrades we were talking about, the NA build will be cheaper but won't get you 400 rwhp even with the overbore , if I had 2 engines I would build a killer FI motor, and the crank can handle some power but it will be a weak link in a FI set up
Old 05-21-2012, 06:43 PM   #24
What do you mean it would be a weak link?
Old 05-21-2012, 06:47 PM   #25
Rm360's Avatar
The crank can handle about 600 flywheel hp it would be at its breaking point in the FI set up we were talking about
Old 05-21-2012, 07:15 PM   #26
Oh okay I gotcha now, would I need to upgrade my clutch and flywheel or anything?
Old 05-21-2012, 07:29 PM   #27
Re: Bore 30 over
stock crank can handle over 600RWHP!!!!! its funny the people that say the stock crank cant handle anymore than 600 flywheel hp never even seen a stock crank broke.. i have only seen one break and it was at 700rwhp and the guy was spinning it 7200 rpms...rpms and vibration killed that crank since it was also on the stock balancer..
also just go 20 over...a stroker shortblock is a .020 bore with the stroker crank and rods not .30 over....over boring gains no power acutally....reason more people go .20 over on used block is to get fresh cylinder walls..if you go .30 over then you have no more cylinder wall play if you have any problems you will need to by a new block..just stcik to going just .10-.20 overbore..
also with the designed on the long runners of the trickflow intake it is a high rpm intake so i would suggest staying with the stocker or getting the eddy...the stock intake is good to 700rwhp...the trickflow intake may PEAK better numbers but the power under the peak suffers alot...its a bad *** powerband you want not just peak..when your racing your not staying at 6000+ rpms all the time lol..
and just some useful info the fastest n/a 2v runs a stock cast crank and spins 9200+ rpms and runs mid 9s
slow02gt is offline   Reply With Quote
Old 05-21-2012, 07:29 PM   #28
Rm360's Avatar
Yes to both ! Anytime you want to make more power you want to build all other parts to handle the new power and torque! Building a car isn't cheap to do it right it's very time consuming and it takes time unless your a millionaire! LOL I've been building my car for about 4 yrs now and I still have a ton of stuff to do but I love my car and don't have any plans of getting rid of her
Old 05-21-2012, 07:30 PM   #29
Re: Bore 30 over
OP what are you wanting a nasty n/a setup or a decently boosted setup?
Old 05-21-2012, 07:37 PM   #30
I want a nasty n/a setup but later down the line want to supercharge it, but if I bore .20 over will I see any hp gains from it with trick flow heads and stage 2 cams with longtube headers and diamond pistons with new springs and rocker arms?
Old 05-21-2012, 07:49 PM   #31
Re: Bore 30 over
like i stated b4 you wont see any gain really with just boring the motor...they do to get fresh cylinder walls...will you see a gain going with the setup you just posted yes from the heads and cams..see you are contradicting yourself... you can have a decent n/a setup and boost it later your not going to have a nasty n/a setup because in order to have a nasty n/a setup you need to up the compression to abou 11:5:1,custom cams,full exhaust,etc,etc...which wouldnt be to boost friendly...if you have e85 around i would do the shortblock at least 10:1-10:5 and with e85 when you go to boost it..you can still boost the sh*t out of it and still be pump gas(e85)
Old 05-21-2012, 08:14 PM   #32
Now how would you up the compression? While your telling me all this I'm learning as we go haha
Old 05-21-2012, 09:23 PM   #33
I see no real benefits of boring out an engine that much, if most just .20 but .30 seems a bit to exesive on a engine that already has pretty thin cylinder walls. If your going to boost your going to need as much cylinder wall as you can get. If you really want to make big power nothing beat the 03-04 cobra blocks(only blocks I trust) with a termi crank, manley rods and pistons you'll have a shortblock that will handle anything you can throw at it.
Old 05-21-2012, 09:36 PM   #34
t0t4lbl4ck0ut's Avatar
You know a terminator block is the same as cast iron gt block and your not boring 2-3 tenths, your going hundredths .020 not .20 unless your planning on going to a 5.0 big bore which you can do safely.
t0t4lbl4ck0ut is offline   Reply With Quote
Old 05-21-2012, 09:38 PM   #35
Mile high JDF's Avatar
You bump it up a couple different ways: you can mill the deck on your block, get the smaller cc TFS heads, or get domed pistons. Any one of those will bump up compression, assuming you keep the same size head gasket if you mill the deck.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
02:50 PM
