wheel bearing - Mustang Evolution
Old 05-22-2012, 08:16 PM   #1
wheel bearing
ok, i just replaced my wheel bearing on my passenger rear wheel. right now its still in the air, no brake hardware on it yet, but the pinion shaft is in. should there be any play on the axle in and out? the other side is still all together and im not wanting to take it apart to find out.
Bosaliniee is offline   Reply With Quote
Old 05-22-2012, 10:47 PM   #2
Voltage258's Avatar
Region: Utah
Re: wheel bearing
I have no clue. But why not change the other wheel bearing while your at it. If one went out the other has to be almost just as worn.
Voltage258 is offline   Reply With Quote
Old 05-23-2012, 12:43 AM   #3
Re: wheel bearing
When you put the bolt back in where the spider gears in the dif, you shouldnt get any play. I think you are allow some play but little at that. If you get too much play it will wear the bearing out...before you bolt everything back up call your local speed shop, or someone that does that install of ring and pinion sets or etc and they will be able to tell you.
southernstang00 is offline   Reply With Quote
Old 05-23-2012, 06:41 PM   #4
Re: wheel bearing
once i got it all back together it was fine. before i could grab the wheel and it would go in and out.
Old 05-23-2012, 10:30 PM   #5
Re: wheel bearing
ohok thats good to hear...dont ya love it when a plan comes together lol
01:47 PM
