Intake installation - Mustang Evolution
Old 05-24-2012, 12:17 PM   #1
Matticus's Avatar
Intake installation
So I'm planning on doing some intake work this summer. I've already got the CAI, and I want to put on a 70mm tb, plenum, and a better intake manifold. Was hoping to get a little advice from people who have done this sort of work on how much labor I'm going to be doing and any general advice.
Matticus is offline   Reply With Quote
Old 05-24-2012, 04:50 PM   #2
02PONY's Avatar
About 1to 1-1/2 hrs if it's your first time
---------- Post added at 04:50 PM ---------- Previous post was at 04:50 PM ----------
Intake manifold 3 hrs
02PONY is offline   Reply With Quote
Old 05-24-2012, 06:00 PM   #3
Matticus's Avatar
Will I have to take the alternator off to get to the intake manifold? I couldn't tell just by looking
Old 05-24-2012, 08:08 PM   #4
02PONY's Avatar
Ya
Old 05-24-2012, 09:13 PM   #5
Mustang_Madness's Avatar
Re: Intake installation
Its actually really simple man! i took mine off a few times to understand it, clean the gasket casings, and pretty much see it all. the CAI is easy, just keep those bolts together. Then after that, BAG every bolt with a group name. like fuel rail bolts, intake to engine bolts, Throttlebody to intake bolts, and so on. that way you can't forget where they go. and if its your first time, take a few pictures as you go to remember where to put things back. Yes you have to take off your alternator which is Really simple, because the belt has a tensioner that you can loosen up. and unbolt the alternator, and there ya go! please don't break off the bolt when tightening up the power wire to the alt. though.. It just snapped off when i did cuz i tightened too much and had to buy a brand new alternator Just because of it. it has a red cap over it. you'll see... haha but i suggest replacing gaskets if your taking it all off already. better seals, no vacuum "leaks", and makes you feel better about yourself. your looking at about 1 hour if you follow instructions, or at least around there, and progressively cut it down to maybe a half hour if you know what your doing. hope it helps!
K&N CAI, Cobra 18" Rims, Cobra Brakes, More Mods to come!
Mustang_Madness is offline   Reply With Quote
Old 05-24-2012, 11:24 PM   #6
Matticus's Avatar
Thanks a bunch man! I'll definitely refer back to this once I get my parts and get started.
Old 05-25-2012, 03:45 AM   #7
[QUOTE=Mustang_Madness;1161424]Its actually really simple man! i took mine off a few times to understand it, clean the gasket casings, and pretty much see it all. the CAI is easy, just keep those bolts together. Then after that, BAG every bolt with a group name. like fuel rail bolts, intake to engine bolts, Throttlebody to intake bolts, and so on. that way you can't forget where they go. and if its your first time, take a few pictures as you go to remember where to put things back. QUOTE]
Was you in aviation before? lol....but is there such a thing as a better intake or better flowing intake other then stock? If so where can you get it?
southernstang00 is offline   Reply With Quote
Old 05-25-2012, 03:58 AM   #8
Matticus's Avatar
Well mine is an 01, so they came with a plastic intake manifold (which I have no idea why they did that) so im getting an aluminum one. AM has some better flowing ones, ford racing and typhoons
Old 05-25-2012, 04:15 AM   #9
yeah I just noticed them but I wondering if its worth the money to buy for the H/p and benifits you gain...?
Old 05-25-2012, 11:45 AM   #10
YES YES YES. nuff said. Getting a PI intake with a tune, as well as a TB and CAI can will definitely make you feel a difference in power off the line, HP, and TQ. Not so sure about the typhoon.. someone would have to help me on that. I've heard mixed opinions on those
Old 05-25-2012, 12:37 PM   #11
If I go with a intake, im def going with the EDB one lol I think im going to order it lol since im putting a supercharger on....
Old 05-26-2012, 09:25 AM   #12
CodyNelson's Avatar
Region: West Virgina
He already has a PI intake manifold. Getting another one will be no different. And they typhoon is junk
Old 05-26-2012, 09:26 AM   #13
Matticus's Avatar
I'm planning on getting the trick flow one that has the plenum in the kit.
Old 05-28-2012, 12:22 AM   #14
Trick flows are Amazing. you won't be disappointed
Old 05-28-2012, 01:42 AM   #15
After reading the description of the trick flow intake and it talking about the ported heads and 75mm throttle body I think im going with it over the Edelbrock Victor Jr. EFI Intake Manifold
Old 05-28-2012, 10:38 AM   #16
Matticus's Avatar
Yeah from all I've seen it seems like the best of the bunch lol
Old 05-28-2012, 11:32 AM   #17
Yea I def agree, esp with the mods I have done already and the ED claims you will have to buy a 90 mm throttle body but the Trick flow recommends the 75mm.
Old 05-28-2012, 12:01 PM   #18
04Mstng.GT's Avatar
Can y'all explain the throttle body a lil more as in "70mm 75mm" stuff like that what does that mean
04Mstng.GT is offline   Reply With Quote
Old 05-28-2012, 12:14 PM   #19
Matticus's Avatar
Bigger size allows more airflow and better performance. That trick flow manifold fits perfect with a 75mm tb, and is a good manifold by itself. Someone else can probably go into better detail.
Old 05-28-2012, 12:18 PM   #20
04Mstng.GT's Avatar
Ima get a bbk cold air with 75mm TB and tuner sound good?
Old 05-28-2012, 12:19 PM   #21
Matticus's Avatar
That's the same CAI I have and same tb I'm getting, so yeah I'd say that's good lol. Just make sure your plenum and everything match up size wise
Old 05-28-2012, 12:21 PM   #22
04Mstng.GT's Avatar
Ok Awsome much appreciated with that u will be able to hear air flowing?
Old 05-28-2012, 12:26 PM   #23
Matticus's Avatar
Not sure, all I can hear is my exhaust XD American thunder catbacks
Old 05-28-2012, 12:57 PM   #24
What you are referring to is the throttle body spacer....for some reason it makes a sucking noise when you hit the throttle. I have a friend and his car does that but you mainly hear it from the filter area though. It also can be the type of CAI that makes the noise too. Its mixed reviews on that, the noise can be a good thing far as you have a good air flow and good vaccum. The bad thing is there is a air leak somewhere in the seal of the CAI itself. IMO.....
---------- Post added at 01:57 PM ---------- Previous post was at 01:55 PM ----------
If you get it before I do then let me know whatcha think about it and how it made your car run. You have two months lol.....just pm instead of in here .
Old 05-28-2012, 12:58 PM   #25
04Mstng.GT's Avatar
Is there a common point were exhaust leak happens? Its getting pretty bad its not underneath
Old 05-28-2012, 01:11 PM   #26
Exhaust leak? where does the noise sound like its coming from?
Old 05-28-2012, 01:13 PM   #27
04Mstng.GT's Avatar
Yea and somewhere up front
Old 05-28-2012, 01:18 PM   #28
thats can be a few things...start a new thread and we will see what we can find out
08:21 AM
