exhaust problems - Mustang Evolution
Old 05-28-2012, 01:20 PM   #1
04Mstng.GT's Avatar
exhaust problems
My leak is getting bigger dont want that!!?? Its not coming from my pipes underneath
04Mstng.GT is offline   Reply With Quote
Old 05-28-2012, 01:21 PM   #2
Matticus's Avatar
It wouldn't be a cracked intake manifold, would it? I know thats a common problem, especially with the plastic ones, that can cause leaks.
Matticus is offline   Reply With Quote
Old 05-28-2012, 01:37 PM   #3
04Mstng.GT's Avatar
To be honest I wouldn't know my first GT n i never had a leak with my past vehicles
Old 05-28-2012, 01:37 PM   #4
Re: exhaust problems
The easiest way to find out where the leak is coming from is to get underneath the car and see if you can see a black sut anywhere on the manifold gasket, manifold,or where the bolt up to the exhaust itself. Have you replaced the stock h pipe when a aftermarket one?
southernstang00 is offline   Reply With Quote
Old 05-28-2012, 01:40 PM   #5
04Mstng.GT's Avatar
Well I bought it used on the side an its got xpipe but even then I got underneath it other day an looks like its been rigged lol different size tubing everywhere pisses me off gonna replace all but not to sure on what to get either all I know is I want it like the roush coming out the skirts but I dont really know my options with that
Old 05-28-2012, 01:47 PM   #6
Well in that case it can be alot of things....I would still see if you can see a black soot near the manifold to block or on the manifold...
Old 05-28-2012, 01:48 PM   #7
Matticus's Avatar
What kind of manifold do you have?
Old 05-28-2012, 02:10 PM   #8
04Mstng.GT's Avatar
Its whatever stock GT comes with I have no after market
Old 05-28-2012, 02:13 PM   #9
Matticus's Avatar
Is it plastic or aluminum?
Old 05-28-2012, 02:21 PM   #10
prolly alu
Old 05-28-2012, 02:24 PM   #11
Matticus's Avatar
Hmm, id check it good anyways. If it was plastic, that would almost definitely be your problem
Old 05-28-2012, 02:28 PM   #12
i agree...
Old 05-28-2012, 03:53 PM   #13
04Mstng.GT's Avatar
plastic just now got to look
Old 05-28-2012, 04:25 PM   #14
Matticus's Avatar
I'd check the other things too, but I'm guessing that's your problem. Those things crack as easy as egg shells.
Old 05-28-2012, 04:47 PM   #15
04Mstng.GT's Avatar
Well damn and if its cracked or anything is it fixable or shall I just get new one but not plastic
Old 05-28-2012, 04:50 PM   #16
Matticus's Avatar
It's probably fixable (not positive) but I would just get a new one to prevent further problems. I'm getting the trick flow one mentioned earlier in the other thread. Just be sure to get aluminum if you get a new one.
Old 05-28-2012, 04:52 PM   #17
04Mstng.GT's Avatar
Ok cool I love this app very helpful lol does that trick flow add horse power or? ??n if so how much
Old 05-28-2012, 05:04 PM   #18
Matticus's Avatar
It does a good bit, I'm not sure the estimates though. AM just says greatly improves performance in the powerband of 1500-6500 rpm. It'll be even better with a matching throttle body.
Old 05-28-2012, 05:52 PM   #19
04Mstng.GT's Avatar
Well right now I'm looking at bbk CAI with 75mm TB and tuner from stage 3ms
Old 05-28-2012, 11:04 PM   #20
it also helps if you heads are ported and polished along with the trick flow.... You have plastic EXHAUST MANIFOLDS?
---------- Post added 05-29-2012 at 12:04 AM ---------- Previous post was 05-28-2012 at 11:55 PM ----------
Well if you are referring to your EXHAUST MANIFOLD, not intake, then I think I have my stock manfoilds still put up in the attic that you can have just pay shipping for them.
Old 05-29-2012, 11:35 AM   #21
04Mstng.GT's Avatar
My intake manifold is plastic
Old 05-29-2012, 11:38 AM   #22
yeah I know lol mine is too...
Old 05-29-2012, 11:40 AM   #23
04Mstng.GT's Avatar
Ok so replacing that will be how much?
Old 05-29-2012, 02:19 PM   #24
A intake manifold that sits on top of the engine would cost like a hundred on up to buy a new one. To replace it, its not hard to do you can do it yourself but if you had a shop do it might be 200 or more in labor im guessing. But you have a exhaust leak, your intake manifold doesnt have anything to do with this....
Old 05-29-2012, 02:50 PM   #25
Lorraine's driver
ab_mach1's Avatar
So, I wonder if the motorcraft factory replacement intake is plastic too?
Instagram: @ab_mach1
Old 05-29-2012, 05:30 PM   #26
04Mstng.GT's Avatar
Well oh my damn lol best thing to do is replace the whole damn thing
exhaust
06:22 PM
