2001 bullitt fuel pressure test - Mustang Evolution
Old 05-28-2012, 09:17 PM   #1
I just did the fuel pressure on my bullitt , sopoustly on the hains manual it has to be on idle around 40-70psi and after 5minutes no less than 5psi drop, mine marks 30psi at idle and went off marks 40psi and no drop after 5-10 minutes
bullittnegro is offline   Reply With Quote
Old 05-28-2012, 09:20 PM   #2
Old 05-28-2012, 09:21 PM   #3
Old 05-28-2012, 09:34 PM   #4
bullitt1075's Avatar
Send a message via Skype™ to bullitt1075
Welcome to the forum, from one Bullitt owner to another. Have you modded your car at all? Post pics.
Proud owner of Bullitt #1075
bullitt1075 is offline   Reply With Quote
Old 05-28-2012, 10:59 PM   #5
Re: 2001 bullitt fuel pressure test
whats the car doing? not running? not running well?...Check engine light?
southernstang00 is offline   Reply With Quote
Old 05-29-2012, 09:06 AM   #6
well Is running from 1 to 10 I say a 8-9 I have cai,x-pipe,magnaflos,(stock bullitt tips)spec-1,billett steel flyweel,accel coils,predator custom 91tune,o2,egr off,steeda shifter,ac deleted(everyting removed), stock gears,
Old 05-29-2012, 09:11 AM   #7
oh well what made you want to do a pressure check on it for?
Old 05-29-2012, 09:11 AM   #8
I just did the fuel pressure test just because the car has 111229 in it and just notice the readings I got different from the book , also my gauge could b rong because in the live data in the predator it marks 45psi car off , the car still has some balls on it just maybe planning on swaping the pump and if stock still good sale it in craiglist, am goin to do the compression test these week ill see if I need a new head gaskets trow in some comps while open to save time
Old 05-29-2012, 09:17 AM   #9
I want to say thats about normal man for high milage car, if the car is running in top notch I wouldnt worry too much about it. If you have no codes or engine light then I would leave it alone. You might be able to change the fuel filter and maybe the fuel pump sock. Put IMO I think it has something to do with the tune, try taken the tune off and see what results you get then. A head gasket doesnt have anything to do with your fuel pressure man.
Old 05-29-2012, 04:58 PM   #10
I know I just have the time to change the gasket if compression test is low because I need to see were is leaking oil by rigth corner maybe by timmingchain cover or in between head and block b cause its been loosing a lot of oil lately
Old 05-29-2012, 10:21 PM   #11
well take you spark plug out and do a compression check on the eng and see if one of the Cyn is low. If you do decide to do a head gasket I would just recommend pulling the engine out and doing both sides. To me it was easier to work on the engine outside the car, esp removing the heads gives you more room to work. If it is in the right corner then its prolly a gasket, I do know if you dont place a dab of RTV on the front on the engine where the heads meet the block, and timing chain it will leak oil....if you dont know what im talking about i will see if I can find a picture.
Old 05-29-2012, 10:38 PM   #12
yeah I did last time I did the timmingchains
Old 05-29-2012, 10:47 PM   #13
Just let me know whatcha find out when you check the compression and etc...
« Tick | Race day! »
05:58 PM
