Which header gaskets and bolts are best for long tube headers? - Mustang Evolution
Old 05-28-2012, 11:57 PM   #1
FordAddict's Avatar
Hey guys! This is my first post so here it goes...
Once I purchase my new GT, it's getting lots of work done to it! I'm going to put on some stainless steel headers (either bbk or pypes) and I was wondering which gaskets you recommend. Also which header bolts do you recommend? I was looking at some stage 9 or something bolts that are lockers and used in aviation. Would these be good? They're made for the headers.
Thanks for your help!
FordAddict is offline   Reply With Quote
Old 05-29-2012, 12:24 AM   #2
Re: Which header gaskets and bolts are best for long tube headers?
On my headers I just used the Felpro kind from autozone and they work great for me. As long as they are metal and not paper then your good IMO cuz i used the paper ones and they were crap. Bolts, I used the header bolts from summit, but I have heard if you can use some of the studs it will help as well.
southernstang00 is offline   Reply With Quote
Old 05-29-2012, 07:10 AM   #3
onesickstang01's Avatar
Ford oem gasket works best. American muscle sells ford racing that are great. Stage 8 locking bolts are a good idea
onesickstang01 is offline   Reply With Quote
Old 05-29-2012, 11:44 AM   #4
FordAddict's Avatar
If the gaskets that come with headers are metal, are they OK to use?
Old 05-29-2012, 02:15 PM   #5
yeah IMO...as long as they arent plain paper...what brand of headers?
Old 05-29-2012, 05:53 PM   #6
FordAddict's Avatar
Either pypes or bbk
Old 05-29-2012, 10:09 PM   #7
oh, those im not sure about but I have bbk right now that are waiting to be put on. Either way im not using the ones that come with the headers, im going to go with the Felbro gaskets at autozone they are only like 5 bucks and awsome IMO.
Old 05-29-2012, 10:17 PM   #8
FordAddict's Avatar
OK. Autozone > Ford racing? Or are they the same?
Old 05-29-2012, 10:32 PM   #9
I looked up the ford racing ones, I mean they are good I couldnt really tell if they are all paper or combo of paper and metal. Go here and click on the picture of the gasket and you will see that its thicker and made of both metal and paper. I have used them on my Gt and had no problems what so ever.
Felpro/Exhaust Manifold Gasket (MS92568) | 2000 Ford Mustang GT 8 Cylinders X 4.6L SFI SOHC | AutoZone.com
Old 05-29-2012, 10:38 PM   #10
FordAddict's Avatar
Is there a difference between the ones that have the 4 connected vs the 2x2 per header?
Old 05-29-2012, 10:49 PM   #11
naw, no difference....
Old 05-29-2012, 11:25 PM   #12
FordAddict's Avatar
Now when I install the headers, how do you keep the gaskets on before the bolt up?
Old 05-30-2012, 05:27 AM   #13
i placed a little bit of high temp RTV around one of the bolt holes in each corner of the gasket and placing it agasint the engine.
Old 05-30-2012, 07:15 AM   #14
Ford racing are all metal. Are you using studs or bolts? If studs just put two studs in the corners of where the gasket will be and slip the gasket on and then the header. Bolt down. If bolts the then rtv trick is the better solution unless you want to use the studs just to hang the gasket and header them put the other bolts in, remove the studs and replace with the new bolt.
Old 05-30-2012, 08:37 AM   #15
FordAddict's Avatar
I was planning on using stage 8 locking bolts. How do you use the studs? Do they come loose any?
Old 05-30-2012, 11:33 AM   #16
I used the studs in areas where I couldnt get a bolt in there. if you want to remove the studs you need a stud remover you can pick up at a hardware or parts store. In some places you can use the studs but this time im going to use grade 8 header locking bolts.
08:43 AM
