31 or 33 spline - Mustang Evolution
Old 05-29-2012, 10:29 AM   #1
t0t4lbl4ck0ut's Avatar
31 or 33 spline
M gonna rebuild my rear end and wasn't sure the capability of the 31 spline. I know 33 is enough for what I plan on doing but If 31 is enough I'll stick with it for availability of diffs. I'm planning on building a 5.0 big bore with forged internals trick flow heads and a kenne bell 2.6 running around 25 psi. Should make around 650-700 rwhp at full boost but that will only be at the track. Street driving I'll only run around 15 psi. I just don't wanna build a 31 spline rear end and have it break and have to do it all over again.
t0t4lbl4ck0ut is offline   Reply With Quote
Old 05-29-2012, 02:17 PM   #2
Re: 31 or 33 spline
31 is just fine...and that thing better damn sure make over 650 on c16 and high boost lol...
people have been 8s with 31 spline.. i even went with it and a e-locker..
slow02gt is offline   Reply With Quote
Old 05-29-2012, 03:55 PM   #3
Lol well those numbers are guesses based off of another build I've seen. A 4.6 bored .020 over with 9.0 compression with ported pi heads, stage 2 off the shelf comp cams, and a kenne bell 2.1 made 717 at the engine on 18# of boost. And at that point the 2.1 becomes very inefficient unless modified which this wasn't. So I assume that with 25 lbs of boost at a efficient level on a bigger supercharger with meth injection and better heads that it should make numbers like that.
Old 05-30-2012, 08:18 AM   #4
Re: 31 or 33 spline
nobody goes by engine dyno numbers..because your cant...the variables are to many because the motor is running no accessories..with no load on it really.. but i have dont a 2.6 build with trickflow heads,comp 270s at 15lbs on pump gas 93 and thru a 4r70w it made 600 on a safe tune...
Old 05-30-2012, 09:27 AM   #5
2002VertGT's Avatar
I like those numbers....I would love to get my very up around 500-600
4.10 Gear/RPM thread
06:27 AM
