Tick - Mustang Evolution
Old 05-29-2012, 11:50 AM   #1
2000_gt's Avatar
Tick
When I get to 2 1/2 rpm I hear a tick until I shift and then it want do it agin until 2 1/2 next gear in every gear at 2 1/2. Can anyone tell me what it might be
2000_gt is offline   Reply With Quote
Old 05-29-2012, 01:10 PM   #2
Jlt00bluegt's Avatar
Have you checked the oil?
Jlt00bluegt is offline   Reply With Quote
Old 05-29-2012, 05:18 PM   #3
2000_gt's Avatar
Yes oil is fine. I change oil every 3000 miles and everything
Old 05-29-2012, 05:34 PM   #4
Stockish302's Avatar
My friends stang started like that if its comming from the front of the engine it might be the chain tensioner. Does it only do it under load or also when you rev it up?
BBK cai, 96 tbird maf housing, BBK 70mm TB, TFS intake manifold, BBK shortys, bassani off road X pipe, Flowmasters with turndowns
If any one is willing to donate parts to the Make Joe's Mustang Faster that Corvettes Foundation, donations will be gladly appreciated
Stockish302 is offline   Reply With Quote
Old 05-29-2012, 06:40 PM   #5
2000_gt's Avatar
Only in gear at 2500rpm
Old 05-29-2012, 10:46 PM   #6
Re: Tick
I agree, if you decide to do this yourself replace it all, tensioners, guides, and chain because a worn guide can cause play in the chain causing chain splapp at times. When i had a noise like this and read a article that it was the chain causing a noise like that, the chain would be wore out where it meet the gear causing play which cause a ticking noise. Unforuntaly, long story short my problem was the cam bolt lost its TQ and allowing the sprocket to backed off and the noise I was hear was the cam sprocket whobble back and forth on the cam shaft until it broke.
southernstang00 is offline   Reply With Quote
09:53 AM
