dual cold air intake - Mustang Evolution
Old 05-29-2012, 03:03 PM   #1
shadow commando's Avatar
Do they make these for gt's? And if so where can I find one?
shadow commando is offline   Reply With Quote
Old 05-29-2012, 03:13 PM   #2
fultonboy09's Avatar
It wouldn't help you unless you have a bigger throttle body, and then you would need to have a bigger exhaust. Remember: you can only force as much air into the engine as the port allows... so if you allow 300ci air through the intake but the ports can only handle 30ci (no idea about numbers, just an analogy) then the big huge intake is absolutely worthless. It could actually hurt performance too because it would decrease the velocity of the airflow. Or would it? I would research a LOT. I will admit that when I saw this my ears perked up lol it would look bad ***!
fultonboy09 is offline   Reply With Quote
Old 05-29-2012, 05:10 PM   #3
It would! I went to advance auto parts and saw it there and it looked sikk!! I just didn't know what all I would need for it to work right.
Old 05-29-2012, 05:33 PM   #4
that's more like for carbs or chrysler/dodge that don't have massflows, but for mustangs 3" is enoft and single and for v6 2" to 2 1/2" be fine,
---------- Post added at 05:33 PM ---------- Previous post was at 05:31 PM ----------
I have 4" in mine since I have a dual trouttle, and calibrated massflow bbk, and tune
bullittnegro is offline   Reply With Quote
Old 05-29-2012, 06:16 PM   #5
So it won't work on a mustang?
Old 05-29-2012, 10:43 PM   #6
?not sure ,dont recomend it ,wont look right
Old 05-30-2012, 05:10 PM   #7
runvsofthisbull's Avatar
Re: dual cold air intake
Not really the one you saw was probably like previously said for a carborated or lsx motor build like on corvettes or camaros that have a throttle body up front and center which allows you to run a kit like that. Honestly cold air is good for a few hp, but nothing drastic, unless you have a 03-04 cobra and/or Shelby gt500 your gains will be much less...5-12 is about avg. It's still worth it IMO though to run it vs e stock system.
2002 True Blue V6 to GT Vert
16.1@86 as an auto 3.8
cold air intake
06:51 PM
