Trickflow Intake - Mustang Evolution
Old 05-30-2012, 11:59 PM   #1
Trickflow Intake
Does anyone have the trickflow intake installed on there car? If so can you post some pictures of it? Did you noticed a difference in how the car runs and what mods do you have done? Worthy for the power you get for the money? I am planning on running a supercharger around 9-11 lbs and I already have all the mods done to upgrade to a charger.
Trick Flow Mustang Track Heat Intake Manifold - 75mm (99-04 GT) TFS-51811002 - Free Shipping!
southernstang00 is offline   Reply With Quote
Old 05-31-2012, 02:10 PM   #2
onesickstang01's Avatar
I thought you were going edelbrock? Stick with the eddy setup for sure
onesickstang01 is offline   Reply With Quote
Old 06-01-2012, 12:02 AM   #3
Re: Trickflow Intake
They only thing about the Edelbrock i dont like is the fact that it that you have to run a race COMP style throttle body and I dont want to. I still want to use my 75 mm throttle body and it recommends you use a 90 mm. The trick flow I can still reuse my same throttle body without having to buy a extra adaptor for it. The Edlebrock kinda scares me, I dont want to order it and it not work im goin to think on it because there is a plate I cam buy from a site that I can reuse my plenium with throttle body.
Old 06-01-2012, 06:54 AM   #4
Yea you can use the mmr adapter plate to run factory style throttle body but the best route is to use the 6061 plenum on the edelbrock and use 75mm throttle body with that plenum. The eddy flows better than the trickflow. Either way its better than the stock plastic but the eddy is for sure a better intake.
Not to mention i believe the trickflow will need bullitt style throttle cable and unless they are making a different style now it uses the twin style throttle body. If they do make it in single gt style throttle body that would be the choking point i would guess.
Old 06-01-2012, 09:15 AM   #5
yea, I saw the plate but i wonder if you can use the 6061 plenum and still use my 75mm throttle without troubles of it not bolting up? Also, I wonder if it has the areas where heater core hoses hook up too.
Thats what i was looking at if the trickflow needs the twin throttle body setup...
Old 06-01-2012, 09:20 AM   #6
Yes i use the 6061 and a bbk 75mm throttle body. And there is a brass nipple for the heater core hook up on the eddy intake
Old 06-01-2012, 09:36 AM   #7
stay with your stocker or do an eddy..the trickflow intake will just make more PEAK hp...the entire power band will be better with the stocker...your still not running enough boost to be able to utilize any after market intake and either choice will be a waste honestly...can make 700 with the stocker..
slow02gt is offline   Reply With Quote
Old 06-01-2012, 11:18 AM   #8
SO you have this on your car now?
I might just stick with the eddy then cuz its 359 and the elbow is like 109. But I did notice that the elbow for the eddy doesnt have a place for the idle air or vac you lines for...
Slow02GT im might be running low boast right now but I might want to go more later on...
Old 06-01-2012, 11:47 AM   #9
Yes i run the eddy intake, 6061 plenum, bbk 75mm t/b. there is a threaded port in back of the plenum on the intake that you use a barb and run all vac off of. 6061 plenums have several options for iac and fittings for other vacuum sources. 6061 plenum doesnt have a egr hookup though that i know of. Simple cap on the exh manifold cleans up that huge mess anyway.
ID:	52633   Click image for larger version
Old 06-01-2012, 11:53 AM   #10
oh wow thats looks awsome, I think im going with the eddy. That really made my mind up cuz its cheaper. 6061 plenum that AM sells I didnt see the option for the IAC thou....
Old 06-01-2012, 12:05 PM   #11
I dont think AM sells anything other than edelbrock elbows. 6061.com or nick at mhs aret he places to get my the elbow i have
Old 06-01-2012, 12:14 PM   #12
ohok gotcha....well 6061 sight wont come up and whats the other site?
Old 06-01-2012, 12:28 PM   #13
Modularheadshop.com
Old 06-01-2012, 12:47 PM   #14
iight, you got me sold on the eddy but on the fuel rails where is the place for you to put the fuel rail pressure sensor? Does it matter what brand of fuel rails you go with, I see BBK has them with a place for the FRPS.
Old 06-01-2012, 01:41 PM   #15
Buy the rail setup from modularmustangracing.com. They have a much better fuel rail design that comes with all fittings and such and ends up being cheaper. You have to use specific fuel rails for the eddy intakes
Old 06-01-2012, 02:24 PM   #16
well im going to do that then, when you put your on did you notice a difference? What all is done to yours ?
Old 06-01-2012, 02:27 PM   #17
Naturally aspirated it makes a difference up top. Supercharged makes huge power difference through entire rpm range
Old 06-01-2012, 02:31 PM   #18
well my engine is new, the heads are fully CNC ported heads, stage 2 or 3 comp cams, LT, 75mm throttle body, SCT tuner and MAS, vortec soon so you think the intake setup would be worth it with all of this ? or should I say would I notice a difference.
Old 06-01-2012, 02:35 PM   #19
Blown cars seem to make around a 10% hp increase with that intake. Bascally same exact setup i have going on. Redoing my vortech setup to go blowthru and much higher boost right now so im NA at the time for my motor break in
Old 06-01-2012, 02:40 PM   #20
Aw okie, have you ran it yet? If so what were your times? ....planning on going with the v-3 vortec 9-11 lbs of boast. The engine is broke in.....
Oh yea, when I do this intake setup would I need it to be retuned?
Old 06-04-2012, 07:28 AM   #21
Have you looked at the new Street intake? I would suggest it if you have not bought your intake yet. As you can see in the graph below there has been some major improvement made to the street intake to maintain great torque and still make the HP that the Track Heat intake has to offer.
Ford 2004 4.6L Stock Short Block 9.68 /1
TFS-519100002-CNC Heads 44 Chambers
TFS-51802001 228/230 @.050 550/550
Stock valve train/ Stock MAC
Name:	TFS-51800002 v TFS-51800000.jpg
Gregg@TFS is offline   Reply With Quote
Old 06-04-2012, 07:38 AM   #22
The street intake made by trick flow? No, I havent see it the only I have seen is the one AM sells. Have a locate that sells it? i havent bought anything yet
Old 06-04-2012, 07:51 AM   #23
You can get it through any of our vendors.
Old 06-04-2012, 08:47 AM   #24
Do you have a vendors website I can check out ?
Old 06-04-2012, 08:56 AM   #25
Trick Flow Specialties TFS-51800000 - Trick Flow® StreetBurner® Intake Manifolds for Ford 4.6L 2V - Overview - SummitRacing.com
Old 06-04-2012, 09:50 AM   #26
gotcha i will check that out and you work at trickflow or something?
Old 06-04-2012, 09:55 AM   #27
Yes I am a tech here at Trickflow.
Old 06-04-2012, 10:49 AM   #28
so the chart shows the different in between the street performer and the one I have in my link?
Explain the chart a little bit better....
Old 06-04-2012, 10:59 AM   #29
It is comparing the Street intake to the Track heat intake on the same bottom end. The Street intake being the one in red. As you can see it provides a much better torque curve through out the entire RMP range and makes more HP up to 5800. At 5800 is where the Track Heat intake takes over.
Old 06-04-2012, 01:46 PM   #30
hmm...yea I saw that..doesnt the 4.6 stop pulling after 5800?
» Members Mustangs
LOU'CY
boink
Baby
Fast 97
Add your Mustang
10:14 PM
