03 GT engine stalling - Mustang Evolution
Old 01-27-2008, 06:32 PM   #1
Question 03 GT engine stalling
Hi all from a new member:
I have what I think is a peculiar problem in that my engine stalls at no particular speed. I can be tooling around the neighborhood, down the interstate it makes no difference. I can feel the engine quit and when I mash the clutch pedal RPM's go to zero. I can dump the clutch, or crank the engine and it restarts. I've seen some threads about the IAC but how would that affect high speed driving? It seems to get worse when the engine is good and hot. When it quits I get a "service engine soon" light but no codes. Watcha think?
midgeorgiastang is offline   Reply With Quote
Old 01-27-2008, 06:42 PM   #2
Re: 03 GT engine stalling
the IAC should only become a problem when the car is idling, in neutral, not when you are giving it gas. If the light goes off when you turn the car back on then its just the cluster lighting up when the key is at the on position but the car is not on.
Old 01-27-2008, 07:25 PM   #3
MonteCitan's Avatar
scan for codes, even if the check engine light is off, something may be stored in memory
It could be anything from ignition to fuel... gotta start somewhere's
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 02-21-2008, 07:08 PM   #4
Hi guys:
Well guess what!! A code did show for my stalling problem and it was the IAC. $460 later I'm back in business. So I guess the IAC can affect engine operation at most any speed or driving condition.
Old 02-21-2008, 07:57 PM   #5
Thomas91169's Avatar
shouldve tried cleaning it with carb cleaner first ($5 fix) rather than spending the $460 from the stealership.
-Thomas-
Old 02-22-2008, 05:38 PM   #6
Hi:
Probably, but the code said that there was an "internal "failure however you want to interpret that.
Car Stalling after disconnecting battery nero 1979-1995 Mustang GT 7 01-17-2011 02:01 PM
stalling 5.0 vil8er New Member Introductions & Greetings 0 02-16-2008 02:12 PM
Car Stalling megax29 Pre-2005 V6 Mustang 7 01-26-2007 09:46 AM
stalling 94 gt wmustanggt 1979-1995 Mustang GT 8 07-02-2006 01:13 PM
stalling on startup Deadmeat101 Pre-2005 V6 Mustang 4 09-16-2003 07:00 PM
06:12 PM
