I need help with this noise. - Mustang Evolution
Old 06-02-2012, 12:16 AM   #1
Voltage258's Avatar
Region: Utah
This is not my car, but this is what it sounds like. As long as im going over 20mph I can hear it, its not super loud but if I have my windows down I can hear it pretty good. When I hit bumps the noise changes a little, but the weird thing is when I press on the breaks even a tiny bit the noise goes away so I was thinking breaks but im not sure anyone ever had a similar problem? Its driving me nuts.
If your getting good gas mileage, your not having fun.
Voltage258 is offline   Reply With Quote
Old 06-02-2012, 12:18 AM   #2
Did u check ur pullies or belt I had to replace one pully on my car it may do the trick
Mady is offline   Reply With Quote
Old 06-02-2012, 12:26 AM   #3
Voltage258's Avatar
Region: Utah
The noise is only there while driving, never idling and it does not change with engine speed. So im thinking its not engine related.
Old 06-02-2012, 12:30 AM   #4
If it happens when the rpm gose up it has to do with pullies and something has to be not moving correctly for their to be a squeak I recommend at least checking the pullies and belt just encase u never know
Old 06-02-2012, 12:33 AM   #5
Speeddreemin's Avatar
Wheel bearings or ball joints maybe. I would say a wheel bearing.
Speeddreemin is offline   Reply With Quote
Old 06-02-2012, 12:33 AM   #6
Voltage258's Avatar
Region: Utah
I will but I can rev up my engine all day and never hear it, it also sounds like its comming from the back of the car.
Old 06-02-2012, 12:35 AM   #7
Hhhmmmm then I really don't know other then to check the gears in the back? It has to be a part that moves so maybe the gears or something in the back
Old 06-02-2012, 12:35 AM   #8
Voltage258's Avatar
Region: Utah
But if its a wheel bearing it should always be making noise, i would not think that applying the brakes would stop it would it? And when do wheel bearings normally start going bad?
Old 06-02-2012, 12:38 AM   #9
No cause I just replaced a wheel bearing in my GT and it would come and go. ...depending on how hot the bearing got. Believe me, when I changed it, it fell apart in my hands. Lol!
Old 06-02-2012, 12:44 AM   #10
Voltage258's Avatar
Region: Utah
Interesting, well mine always does it no matter what, and the braking thing is whats bugging me but I will look into the wheel bearing. And I know all wheel bearings dont go out at the same time but does 40,000 miles seem a bit early?
Old 06-02-2012, 01:05 AM   #11
Anything is possible.
---------- Post added at 07:05 AM ---------- Previous post was at 06:55 AM ----------
40,000 does seem early but it's either a bearing or maybe if it only happens when going over bumps, that it could be a messed up spring isolator? In other words your suspension springs in the rear could be squeaking? I could barely hear the vid so it's hard to say for sure.
Old 06-02-2012, 02:11 AM   #12
Re: I need help with this noise.
ok, not saying ANY of yall are wrong but I don't think it has nothing to do with the engine, brake, drivetrain etc. just saying.If you want to rule out a wheel bearing then the easiest way to do this is go to a empty parking lot or non busy road and move the steering wheel to the left and right real quick as you go over 5-10 mph but do not exceed 20 MPH for safety reason. Depending on what wheel bearing that would be suspected bad as the weight of the car gets on that side it would get louder but I can tell you thats not your problem . That sound is coming from inside of the car and the reason I think that is the sound is too destinct to be engine or wheel bearing. If it was outside of the car the wind would muffle the sound a little bit but that sound is coming right behide you or near you. To me the sound is coming from the back of the car like right behide you.
Here is what I would do before spending any money on parts, get in the back seat of the car and start tapping on the b-pillar panels and work your way back underneath the rear side window panels to right above the rear seat. Tap on the rear seat as well and then fold them down and tap on the frame. DO this on both sides of the car or have someone sitting in the back seat of the car while going down the highway and have them listen for the sound...That sound to me seems like its coming from somewhere inside and the only time you hear it is when you are going over 20mph and the body/frame starts to flex because of road conditions. To see if it is a ball joint lift the car up and put one hand on top of the tire and then the bottom of the tire and try to movie it up and down. If you get play then its the ball joint, from what I have seen in the shop sometimes a ball joint will cause abnormal wear on the tire. Bushings yes, but the only way you would be able to see which one is get underneath the car and to spray each bushing one at time and then drive it and see if the noise goes away If it does then replace the last bushing you sprayed or replace them all. But if the bushing was that worn out you would hear more of a pop instead of a squeaking noise. That sound is more of a squeaking noise. IMO, if it was my car I would do what I said above to rule possible things or test should you say, before I started to buy parts based because that can get expensive. At least have someone ride in the back sit out the road and see if you dont hear it coming from some where back there and let me know.
If need to be and you can give me your number in a PM and one day im off or you have time I will call you and help you out cuz there is something loose somewhere in the back in the cab its self or possible in the trunk.
southernstang00 is offline   Reply With Quote
Old 06-02-2012, 03:52 AM   #13
02PONY's Avatar
Mine sounded almost identical it was front wheel bearing assembly
02PONY is offline   Reply With Quote
Old 06-02-2012, 04:52 AM   #14
So it sounded like a squeaking noise or a roaring noise?
Old 06-02-2012, 06:07 AM   #15
02PONY's Avatar
Mine would squeal almost constantly and almost a howl cornering
Old 06-02-2012, 06:29 AM   #16
Now that does sound like a wheel bearing esp when you when into corners and the weight of the car pushed on that bad wheel bearing.
Old 06-02-2012, 06:39 AM   #17
02PONY's Avatar
All the balls in the hub bearing were in pieces and pile of dust
OP try to get a actual video of Your noise
Old 06-02-2012, 07:52 AM   #18
wow, that def must have neen screaming at you lol..and yes i agree...
Old 06-02-2012, 09:02 AM   #19
Voltage258's Avatar
Region: Utah
Im almost certain its outside the car, when the windows are down it is louder and when you go by fences or park cars you can hear it really good. And the noise does not change when cornering and there is never a howling or popping noise it pretty much stays the same. The only time it changes is when I apply any amount of pressure to the brakes it goes away. I will try to get a video of my noise and post it today. Thanks for the help everyone.
Old 06-02-2012, 09:29 AM   #20
okie thats good info to know then, does it sound like its coming from the front of back of the car....is this a auto or manual?
Old 06-02-2012, 11:17 AM   #21
Voltage258's Avatar
Region: Utah
5 speed and sounds like its comming from the back
Old 06-02-2012, 11:26 AM   #22
How about the wear indicator on your brake pads?
Old 06-02-2012, 11:33 AM   #23
Lorraine's driver
ab_mach1's Avatar
My Goodyear F1's are very noisy, and it's like a roar type sound. There might be other brands that are noisy, but this is no squeak or metallic chirp sound.
Instagram: @ab_mach1
Old 06-02-2012, 11:47 AM   #24
Cobra Seb's Avatar
Check the bolts on the caliper also check the shims on the pads sounds like its the shims if it is put a little grease on them
Cobra Seb is offline   Reply With Quote
Old 06-02-2012, 12:42 PM   #25
Voltage258's Avatar
Region: Utah
I have the wheel off, but have no idea what a shim is.
Old 06-02-2012, 12:43 PM   #26
The shim is inside the caliper between the caliper and the brake pad
Old 06-02-2012, 12:54 PM   #27
Voltage258's Avatar
Region: Utah
Do you need to take the caliper off to get to it?
Old 06-02-2012, 12:55 PM   #28
Yes
Old 06-02-2012, 12:55 PM   #29
Voltage258's Avatar
Region: Utah
Yes
That's a mother. I will have to try tomorrow, I don't think I have the time.
Old 06-02-2012, 01:07 PM   #30
When u do get it apart, get some brake grease from a parts store, (they sell them in little packets.) and coat the areas where the shim sits.
Old 06-02-2012, 01:08 PM   #31
Enorym's Avatar
Buy American made brakepads /notkidding
Enorym is offline   Reply With Quote
Old 06-02-2012, 01:12 PM   #32
Cobra Seb's Avatar
They sit on the brake pad bracket also check to see if ur pads move up an down
Old 06-02-2012, 01:20 PM   #33
Voltage258's Avatar
Region: Utah
Ok here are the videos.
The first one is hard to hear for a second but you should hear it and the second one i taped my phone to the gas tank cover so the exhaust is really loud but you can hear the squeak well.
Old 06-02-2012, 02:09 PM   #34
Lorraine's driver
ab_mach1's Avatar
That's gotta be wheel bearings. Maybe if your brake pads are really old. Does it change immediately when the brakes are applied? If not, it seems to be bearings.
Old 06-02-2012, 02:29 PM   #35
Voltage258's Avatar
Region: Utah
Yes right when I press on the brakes with any amount of pressure the noise goes away. You can kind of tell in the second video if you pay close attention.
04:17 PM
