found a 1998 gt i have $2500.00 to play with - Mustang Evolution
Old 01-29-2008, 10:04 AM   #1
hey guys i found a real nice 98 gt it has some mods and i have 2500 to add some more horse what should i do next i know headers for sure. theres the list
of what she has now i would like to hit the 300 mark i should be close now
bbk cold air intake
bbk throtle body
bbk air filter
ceramic brake pads
drilled slotted rotors
new 3:73
taylor race wires
iridium plugs
passani x pipe
flowmasters
stainless tips
jamestherons is offline   Reply With Quote
Old 01-29-2008, 10:51 AM   #2
Herbstang's Avatar
Re: found a 1998 gt i have $2500.00 to play with
98 GT has 225 horsepower. if it's a 5 Sp your looking at 192 to 195 RWHP Auto about 180 to 185 RWHP. The BBK TB and CAI may give you 10 to 15 more RWHP So if your looking for 300 RWHP you have a way's to go. I'm sure other's will jump in a with more info or correct on my rough caculations.
manual firgure 15% lost thru drive train auto 20% lost
Old 01-29-2008, 11:03 AM   #3
last owner works for a speed shop the last tune he said it was @ 289 hp i don't know if thats bs or not
Old 01-29-2008, 11:18 AM   #4
Herbstang's Avatar
With the mods listed. I don't see the 289 even with a SCT chip or x-cal tuner or any tuner maybe he did more then he's telling you ask for a dyno sheet
Old 01-29-2008, 12:06 PM   #5
ok ill ask i think its bs to !! so what mods do u think i should do next
Old 01-29-2008, 12:56 PM   #6
I'd do a PI swap if it was me...you'll thank me later.
Old 01-29-2008, 09:08 PM   #7
iwannagofast's Avatar
PI swap? whats that? something i have always wondered is what gives the 99 GT 260hp while the 98 had 225 when they both have 4.6 Modular engines?
iwannagofast is offline   Reply With Quote
Old 01-29-2008, 09:45 PM   #8
Scut95's Avatar
The PI swap is different heads and intake....and it is what gives the 99gt 260 compared to your 225....i dont know how much it cost to do the swap though, someone else can probably chime in and tell you that.
Old 01-29-2008, 09:47 PM   #9
good to know cuz i might pick up a 98 gt on tuesday
Old 01-30-2008, 08:11 AM   #10
the 96-98gts are the slowest so they need a good bit of work. A head swap is a great way to boost performance. By doing the 99+ PI swap onto your 98 you will raise the compression and get more power than the 99+ have~ thats not a bad way to start out. With the mods you listed you are no where near 289rwhp.... not even close
Old 01-30-2008, 12:59 PM   #11
sledgehammer's Avatar
Send a message via Yahoo to sledgehammer
whats the cost of a pi swap
94 v6 manual, 3.45s w/t-lock, cai, straight straight through dual exhaust, sct eliminator.
sledgehammer is offline   Reply With Quote
Old 01-30-2008, 01:23 PM   #12
I'm reading that you only get 5 hp from the heads so I'm going to save the money and just do the cams and intake should cost around 800
Old 01-30-2008, 01:31 PM   #13
you might only get five horsepower out of it now, but as lowflyn said "later" is where it will really count. if you go blown your increase will much higher the pi heads and intake than stock 98heads and intake.
Old 01-30-2008, 03:20 PM   #14
most GT's ive seen that go PI swap go above the 99-04 gt's 260hp to about 280-285 (so from your stock 215 to 285) as it raises the compression.. not sure on the TQ probably about the same. You could do a set of custom grind cams (not out of the box cams) and port the heads a bit to help. I cant remember but I think it raises the compresion to near 10:1 or more so you will probably need premium fuel after this.
Try and find someone thats done the PI swap that has dyno numbers to see where they are. They should be 235-255rwhp at least.
You could do a 4v swap but not sure all that is needed... probably be easier buying a donnor 4v and swaping the entire engine.
For Sale: 1986 LX Hatchback - $2500 fast64 Mustangs for Sale and Wanted 0 09-24-2009 07:53 PM
For Sale: 94 V6 Convertible. $2500 Otlaw80 Mustangs for Sale and Wanted 3 07-10-2009 09:29 PM
1996 F-150 $2500 A5295 Mustangs for Sale and Wanted 1 07-08-2008 09:06 PM
Dayum, anyone checked out this USC?? 2500 bucks!! roush4life The Bar 0 08-24-2007 09:14 AM
94 Silverado 2500 for sale 232SCstang Mustang Parts for Sale and Wanted 0 05-02-2004 01:15 AM
01:58 AM
