Pcv broken? - Mustang Evolution
Old 06-04-2012, 09:44 AM   #1
Arron's racecar's Avatar
Region: Nevada
Pcv broken?
Hey every one, I was doing some research on the PCV valve and I'm trying to figure out if mine's broken. I've read online that you should shake it and it should rattle but it's supposed to be spring loaded. Well mine rattles but it's definitely not spring loaded. In fact I don't even see a spring in it. It has an electrical connector on it as well, what is that for? My car is a 2004 gt.
2004 GT current mods : CAI, BBK Short throw shifter TB and UDPs, SCT x3/SF3 with BAMA Perfomance tunes Roush body kit, roush side skirt exhaust and paint.
Arron's racecar is offline   Reply With Quote
Old 06-04-2012, 12:20 PM   #2
Mzilla's Avatar
Here the deal you need to take the valve and suck on the end of it to endure it closes tightly. If it does not seal properly then you need to replace it. Make sure to replace it with a Fors Motorcraft path only. The aftermarket ones are cheap junk
Mzilla is offline   Reply With Quote
Old 06-04-2012, 01:56 PM   #3
Region: Nevada
Ok I've taken it off and I can blow and suck through both ends with no resistance so I guess it's bad. Any idea what the electrical connector is for??
Old 06-04-2012, 02:21 PM   #4
Mzilla's Avatar
The electrical connector is for heating the element for when it's cold outside. The pcv should suck closed on the engine side. It does not seal completely but pretty close
Old 06-04-2012, 10:55 PM   #5
Region: Nevada
I was able to suck through it from both ends with 0 resistance.
Old 06-05-2012, 12:12 AM   #6
Re: Pcv broken?
What made you intrested in the PVC valve? Car not running right or something?
southernstang00 is offline   Reply With Quote
Old 06-05-2012, 05:29 PM   #7
Region: Nevada
Poor acceleration and power loss
Old 06-05-2012, 10:47 PM   #8
Re: Pcv broken?
aw gotcha, well did you get another one and did it fix your problem?
Old 06-06-2012, 06:28 PM   #9
Region: Nevada
Not yet, I'm poor at the moment hoping to get one in next week.
Old 06-07-2012, 07:35 AM   #10
imhooked's Avatar
Re: Pcv broken?
pcv valve real cheap! 5.03 (plus ship) where i get some of my basic parts... pm me if you want to know where-
joe
---------- Post added at 07:35 AM ---------- Previous post was at 07:15 AM ----------
joe
my bad! just noticed, the heated units are a little bit more! 25 bucks actually for the genuine motorcraft pcv.
hope you get 'er back up and running!
imhooked is offline   Reply With Quote
06:34 PM
