under car tick - Mustang Evolution
Old 06-04-2012, 07:05 PM   #1
1shotkllz's Avatar
under car tick
On my way to work today while stopped at a stop light i heard a tick. It got faster as i was accelerating. When i pulled in to work i popped the hood and the tick wasn't coming from anywhere engine wise, more like directly under the engine where the headers connect to the mid-pipe area. Is an exhaust leak in that area possible to cause a tick like that? Oh and i forgot to mention, if i lay into her a little i will get a backfire ocassionally, as well as smell exhaust through my vents. All this just recently started.
Any suggestions will help! Thank you all!
1shotkllz is offline   Reply With Quote
Old 06-04-2012, 07:07 PM   #2
Check your ac unit! I had the same thing in my v6 only instead of a Rick the engine shut off as I was pulling in a parking lot T-T
Mady is offline   Reply With Quote
Old 06-04-2012, 07:15 PM   #3
1shotkllz's Avatar
My a/c wasn't on. Lol, i prefer to ride and listen to my exhaust sing
Old 06-04-2012, 07:16 PM   #4
Check exhaust parts then
Old 06-04-2012, 07:35 PM   #5
Mile high JDF's Avatar
It sounds like an exhaust leak. Is your an automatic or a stick?
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 06-04-2012, 08:07 PM   #6
1shotkllz's Avatar
Manual, and the sound doesn't go away if i push the clutch in.
Old 06-04-2012, 08:11 PM   #7
Ok I was gonna say, the best way to test it is to put the car under some load. Have you tried getting under the car while the engine was running and listening for it?
Old 06-04-2012, 08:19 PM   #8
1shotkllz's Avatar
Thats what i was gunna try tomorrow morning. I know when i do put it under load it will backfire once then its ok after that. There is an exhaust smell coming through my vents if i put her under load too. So thats what pointed me to an exhaust leak
Old 06-04-2012, 08:30 PM   #9
all the signs point towards it. If you want final reassurances find a big hill to drive up and put it in like 4th or 5th and just nail the gas and see if it seems to get worse
Old 06-04-2012, 08:35 PM   #10
1shotkllz's Avatar
HA, i have no hills near me at all! Flat, country land. I'll do some more investigating tomorrow morning if i wake up early enough
Old 06-04-2012, 08:53 PM   #11
Ah ok, good luck
12:27 AM
