best rust remover - Mustang Evolution
Old 06-04-2012, 06:54 PM   #1
foesublime's Avatar
best rust remover
I had to replace my rear brakes and there is quite a bit of rust and brake dust build up that I can't get cleaned. What's the best thing I could use to break it down and scrub it without taking paint off my rims?
foesublime is offline   Reply With Quote
Old 06-04-2012, 08:22 PM   #2
Vegas97gt's Avatar
Region: Nevada
Try just spraying it down with simple green I've heard it takes off surface rust
Vegas97gt is offline   Reply With Quote
Old 06-04-2012, 09:09 PM   #3
Mathew r Wright's Avatar
I just soap and water on the inner part of the rim where all the dust and grim build up, if that's what your talking about? Just soap and water and some SOS pads. Now as far as the outer I wouldn't use the sos pads they will scuff the shiny surface to much...
Mathew r Wright is offline   Reply With Quote
Old 06-05-2012, 04:41 PM   #4
jdavis96gt's Avatar
Region: West Virgina
Re: best rust remover
I used some clr cleaner. Calcium lime rust remover. Worked real good
Old 06-05-2012, 08:33 PM   #5
Yah I would try that that sounds good...
05:03 PM
