SVE vs Steeda Coil on Plugs - Mustang Evolution
Old 06-04-2012, 07:24 PM   #1
MustangGT02's Avatar
Ok my car has a slight miss and I thinks its the COPs. I found two good deals on them and want some opions. My car is a DD and it is out in all weather (Parks out side )
Steeda High Output Coil Packs for Ford Mustang
SVE Mustang GT Coil Packs (99-04) at LRS - Free Shipping!
Thanks for the help!
MustangGT02 is offline   Reply With Quote
Old 06-04-2012, 07:27 PM   #2
Eturner's Avatar
My advice is run a code scanner first before you get the coils!.. Make sure that is the problem, would hate to see you throw some cash down and still have the same problem!..
Old 06-04-2012, 07:36 PM   #3
The Blue Dragon
GrabberBlue5.0's Avatar
I cannot speak for ALL SVE parts but I know that my SVE springs are in fact FRPP springs, paid for the SVE name got the FRPP part, just something to think about....
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 06-04-2012, 07:36 PM   #4
AgentOrange's Avatar
If you know someone with a wand-type coil tester and an advanced scantool see if you can use their tools.. I thought I had a bad coil but I tested mine with a snap-on MODIS and my coils were all within 2k volts of each other, which is fine considering the innacuracy of the tool. I know its a long shot, but coils are expensive and I know a lot of us have mechanic friends or the such.
AgentOrange is offline   Reply With Quote
Old 06-04-2012, 07:58 PM   #5
I have a scanner and it finds nothing, I'm 18 in a city of hardly any people with an intrust in cars so I don't have many resources. I figure I might as well get new ones sence the ones on now are stock with almost 90k miles.
Old 06-04-2012, 08:23 PM   #6
Rm360's Avatar
You said your car had almost 90k have you checked the fuel filter and maybe could be dirty injectors
Old 06-04-2012, 09:36 PM   #7
The whole point is using the conductive wand. You put it on each of your coils and it shows how many volts they are firing at. Just checking codes won't do anything. But, it sounds like that won't be an option so you may have to try for coils. I'd replace fuel filter and use Motorcraft copper plugs and see if you get any difference first though.
Old 06-04-2012, 09:42 PM   #8
Re: SVE vs Steeda Coil on Plugs
Ok guys I have done just about everything a long time ago, new plugs, new filter, cleaned TB, new EGR so im going to buy COPs no matter what just for sh#$s and grins. My question was what brand would you go with?
Old 06-05-2012, 05:29 AM   #9
The Blue Dragon
Old 06-05-2012, 06:38 AM   #10
imhooked's Avatar
did you change plugs already(recently)? assuming YES, i've seen in several threads previous that the general consensus to stay with stock, although there are some fans of the msd blaster cop's. i was thinking of upgrading(changing) mine too, but not really sure if any performance gain would be seen?!
---------- Post added at 06:38 AM ---------- Previous post was at 06:32 AM ----------
oh; just saw you did the plugs... a long time ago?! like how many miles? might be good to just take a look at 'em, and re-check gaps anyway.
p.s. if you like accel, those are about $182 on amazon
imhooked is offline   Reply With Quote
Old 06-05-2012, 07:20 AM   #11
Lorraine's driver
ab_mach1's Avatar
Is there a way he can test his injectors? W/90k, you'd think that could be a trouble spot.
If it was me, I'd replace the COP's w/that mileage. Before that, I would try to isolate the problem.
---------- Post added at 09:20 AM ---------- Previous post was at 09:17 AM ----------
Also, if this only happens at high acceleration, maybe your fuel pump is getting weak.
Instagram: @ab_mach1
Old 06-05-2012, 07:56 AM   #12
just stay OEM on COP's they work great seems all aftermarkets are not very good
Old 06-05-2012, 08:09 AM   #13
It did it before I changed spark plugs and fuel filter. I guess I can pull the plugs tomarow and post some pics, I get paid Friday so I'm can't buy anything tell then lol.
An other thing is when I got my bama tune it causes my car to ping if I run regular gas on the 87 tunes, so i have been using 89 octane gas and it seems to no do it as much but if the car lugs at a low rpm it does it, this causes me to think some thing is wrong some were.
Old 06-06-2012, 05:56 AM   #14
imhooked's Avatar
yup, pinging with the bama tune... had the same problem when i installed mine. there is something you can try, and that is adjusting (taking out some) timing with the handheld.
i currently run my 91 tune with 93 octane gas, and this combination seems good ( i did have some pinging here too, took out some timing, and it was better; then went back to default timing, and still running good, so maybe some variance in fuel quality?!)
how'd your plugs look, is the gap spot-on .054, and did/can you change your fuel filter?
Old 06-08-2012, 09:15 AM   #15
SVE COPs are on their way, I will report back when i install them.
Old 06-08-2012, 09:19 AM   #16
Lorraine's driver
ab_mach1's Avatar
Cool!
Old 06-08-2012, 12:08 PM   #17
imhooked's Avatar
how much were they? do they have higher voltage output than the standard cop's... just curious
Old 06-08-2012, 01:24 PM   #18
$220 and they advertise them as better than stock.
Old 06-09-2012, 05:37 AM   #19
imhooked's Avatar
yeah, i looked at 'em at LMR's site. that's good price; less than 30 a piece!
like the purple sve decal on them too! let us know how you like 'em and if you actually feel any difference in throttle!
Old 06-09-2012, 10:02 AM   #20
Will do, UPS says they will be here Tuesday.
Old 06-12-2012, 09:26 PM   #21
Well they are in, I just finished and drove it around the block. It ran just like normal and I didn't feel any difference. I didn't put my foot in it so I can say any thing on that subject yet. The idle is still rough so i decided if its any thing bad I will just have to wait for it to die, I'm done hunting. I will go out for a more agressive drive tomarow.
Old 07-26-2012, 08:43 AM   #22
Lorraine's driver
ab_mach1's Avatar
How are the new COP's doing in your ride?
Old 07-26-2012, 11:19 PM   #23
They are doing fine, it was not my problem but they seem to be doing fine. I figure up ny mpg every time I fill up and I'm getting about .8 mpg better now. Nothing big in the performance area though.
Old 07-27-2012, 12:54 AM   #24
1shotkllz's Avatar
I'm hunting the same problem, but i probably do need to replace my COPS and plugs. Just gotta get my money first. And figure out whats the best brand
1shotkllz is offline   Reply With Quote
Old 07-27-2012, 07:26 AM   #25
I have decided if its not broke, don't try to fix it. My car idels rough and I was trying to get it smooth. Now I'm just going to save my money and if something goes wrong fix it then rather the replacing something that's still working fine.
Old 07-27-2012, 04:31 PM   #26
1shotkllz's Avatar
Ive always had the idle hunt issue. But now if i put the car under load it starts missing, no codes or anything. Im not sure if its a fuel delivery problem. So im replacing the fuel filter this weekend. I dont believe its a plug problem because it only does it under load. So idling its not missing
Old 07-27-2012, 07:59 PM   #27
LAS97GT's Avatar
Pity, I read all the posts. No one has suggested that you re gap your plugs to a closer tolerance. Bring them to minimum tolerance. If that don't work, cylinder heads may need a comp test. Think about it, it's a mustang. It runs hard. Just my 2 cents.
---Las97GT
Old 07-27-2012, 08:52 PM   #28
Lorraine's driver
ab_mach1's Avatar
Like .054 to maybe .050?
Old 07-28-2012, 05:09 PM   #29
LAS97GT's Avatar
Heck, I put mine at about 35 I think, but my heads are tired. Time for PIs. 50's way too wide.
---Las97GT
Old 07-28-2012, 06:21 PM   #30
Lorraine's driver
ab_mach1's Avatar
So what are the drawbacks to reducing the gap, if there is any?
04:24 PM
