Which springs? - Mustang Evolution
Old 06-05-2012, 09:03 AM   #1
RUNNWLD's Avatar
Region: Utah
Which springs?
I want a racing look of the car. But it's a daily driver can you please help me with what spring I should go with?
RUNNWLD is offline   Reply With Quote
Old 06-05-2012, 11:58 AM   #2
RUNNWLD's Avatar
Region: Utah
Guys will you please help me on what lowering springs to go with?
Old 06-05-2012, 12:30 PM   #3
Horseplay's Avatar
i got dropzones . i luv em. but if u got cash to spend go for h&r springs . and i u reeeeally have cash to blow, forget springs and get coilovers
Low2v
Old 06-05-2012, 12:43 PM   #4
Rm360's Avatar
If its a daily driver I would go with the eibach pro kit you won't need any other upgrades other than new shocks and struts
Old 06-05-2012, 01:35 PM   #5
RUNNWLD's Avatar
Region: Utah
It seems like the pro kit is not a noticeable drop would the eibach sport be to low and would the h&r sport be to low?
Old 06-05-2012, 04:05 PM   #6
Horseplay's Avatar
no such thing as too low ! and no its not that big of a drop. at most 2" depending on ur shocks/struts
Low2v
Old 06-05-2012, 04:21 PM   #7
t0t4lbl4ck0ut's Avatar
Actually there is too low. Especially if you have wide tires and a weak suspension. Before I changed the suspension the previous owner put on the fenders would cut the tire sidewalls because of the suspension collapse. My car had steeda springs(not sure which ones) and tokico shocks and stock control arms. If you do go REALLY low you'd better look at strong spring rates or upgrading your shocks and control arms to keep that from happening. I went with h&r race springs and kyb adjustable shocks and j&m control arms and I don't have any problems now and it didnt raise my ride height any.
t0t4lbl4ck0ut is offline   Reply With Quote
Old 06-05-2012, 05:10 PM   #8
I love my h&r race springs. Currently have cut v6 springs on the back for a temporary fix. All 4 fenders are rolled to clear tires. 275 front and 305 rear
Old 06-05-2012, 05:19 PM   #9
Yea I'm kinda sketchy on rolling the fenders cause nobody around here can do it so I'm like...............
Old 06-05-2012, 05:32 PM   #10
Mile high JDF's Avatar
Do you plan on doing any sort of racing? Like Roadcourse/Auto X type racing.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 06-05-2012, 08:43 PM   #11
I rolled my own. Never done it before my cobra. Zero issues and was quite easy
Old 06-05-2012, 09:16 PM   #12
RUNNWLD's Avatar
Region: Utah
No I won't be racing on track or anything I just want them for looks?
Old 06-05-2012, 09:33 PM   #13
TtownMach1's Avatar
Seen reviews of the H&R race springs. Supposedly they still have good ride quality for a DD, and don't drop as low as the sport springs. Thinking of getting those for the Mach with some upgraded shocks/struts.
5-Speed-IUP, Predator tuned, k&n cai,Mrt shifter,Hooker Lts-o/f x-pipe, KC clutch,Alum flywheel,FR 4:10's. Upr rear control arms. Forged Teksid Eaton swap in progress!
WickedStangs Mustang Club
Tulsa,OK Chapter President
TtownMach1 is offline   Reply With Quote
Old 06-05-2012, 09:34 PM   #14
Then go for the sport springs, the race springs get fairly stiff for daily driving. I personally like H&R springs.
Old 06-05-2012, 09:51 PM   #15
bullitt1075's Avatar
Send a message via Skype™ to bullitt1075
I have H&R race springs and Tokico shocks/struts with the polyurethane spring isolators, and eibach camber bolts. The ride is a little stiffer than the stock Bullitt springs and lowered it another .5 inches in front and .25 in back. I am very happy with them got a DD and I can post some pretty competitive Auto-x times.
Proud owner of Bullitt #1075
bullitt1075 is offline   Reply With Quote
Old 06-06-2012, 12:03 AM   #16
TtownMach1's Avatar
+1 thanks for the input just made my decision lol. I'll sacrifice some ride quality to be able to sling it around the track. I'm also not wanting that much of a drop. Longtubes are low clearance as is.
Old 06-06-2012, 02:55 AM   #17
Yea I'm the same way. I don't think the ride quality is bad at all. I mean you bought a mustang not a Lincoln lol
Old 06-06-2012, 08:58 AM   #18
My pleasure, I love my set up. I went with the camber bolts so I could add more negative camber, but you can probably get away without camber bolts or plates. The turn in on my Bullitt has improved greatly by adding camber, I'm now at -1.5 degrees.
Old 06-06-2012, 09:19 AM   #19
RUNNWLD's Avatar
Region: Utah
If I go with h&r race springs max caster camber plates and tokico shocks and struts would that be good?
Old 06-06-2012, 11:36 AM   #20
That would be a great set up in my opinion.
Old 06-06-2012, 12:09 PM   #21
Timm04's Avatar
How much did you cut off your coils?
Timm04 is offline   Reply With Quote
Old 06-06-2012, 01:15 PM   #22
Yes. That's what my plan is once I can get the funds for shocks and struts.
Old 06-06-2012, 01:17 PM   #23
This is before and after the spring install
ID:	53568   Click image for larger version
Old 06-06-2012, 09:21 PM   #24
Re: Which springs?
If your goal is primarily looks while still maintaining driveability every day, look into FRPP C or B springs, H&R Race Springs, or Eibach Pro Kit springs. These springs drop the car .75" to 1.25"...a noticeable drop from stock but still practical for daily driving. The ride will be stiffer than stock but not unbearable.
FRPP F Springs, H&R Super Sport Springs and Eibach Sport Lines are more aggressive and lower the car +1.75", so they might make daily driving tougher. I have the H&R SS's, and the drop is amazing but low, and the ride is definitely stiffer than stock, but I don't dd the car so it doesn't bother me.
If you use FRPP C springs or Bullitt stock springs (basically C springs), you probably don't need CC plates or new Shocks/Struts, though camber bolts and a set of Bullitt/Mach 1 shocks/struts wouldn't hurt.
As said, for the best results and to avoid premature wear, match your upgraded shocks/struts with the upgraded spring rates. Not doing so will cause your components to wear out much sooner and make for a weak suspension setup.
Old 06-06-2012, 10:37 PM   #25
RUNNWLD's Avatar
Region: Utah
If you get the eibach sport what all do I need if I just want it for looks or the h&r SS springs?
Old 06-06-2012, 11:49 PM   #26
shadow commando's Avatar
Will lowering springs cause the car to scrape the ground on like bumps?
shadow commando is offline   Reply With Quote
Old 06-07-2012, 10:05 AM   #27
Mostly just speed bunps
---------- Post added at 04:05 PM ---------- Previous post was at 04:00 PM ----------
The race springs also are not progressive rate like the SS and sportline springs. Meaning they are one stiffness the whole time, versus progressive rate springs are soft when you first go over the bump but get stiffer the more they compress. Usually the SS and spirtline springs are recommended more for a DD setup because they give you more of a stock feel going over bumps versus the race springs being very stiff.
Old 06-07-2012, 11:18 AM   #28
RUNNWLD's Avatar
Region: Utah
Yeah so I'm going to go with eibach sports. So what is everything I need if I just want it for looks or just the springs?
Old 06-07-2012, 11:34 AM   #29
Your can get away with just the springs IF you don't mind blowing through tires fast. To do it right you need the springs, shocks, struts, caster/camber plates, and a bumpsteer kit.
Old 06-07-2012, 11:47 AM   #30
RUNNWLD's Avatar
Region: Utah
Should I do the eibach or the h&r sports ah this is hard to choose!!! But I will go with the springs and caster camber plates. Then get the shocks and struts and bump steer kit later.
Old 06-07-2012, 12:16 PM   #31
I have camber bolts and I have lots of adjustment with them. Plus they cost a fraction of the price compared to camber plates. They are around $25-30, I'm vet happy with them, and you don't have to drill an extra hole in your shock tower, like you do with 4 bolt camber plates. Just a thought.
Old 06-07-2012, 12:18 PM   #32
Ok. With the springs it really just comes down to which name you like better. Both are very good springs. Also go check what deals AM has on springs this month, that could help you decide
Old 06-07-2012, 12:51 PM   #33
I would actually look at what you want in your spring and go from there. Your stock springs are 400lbs and rears are 180ish lbs, so I would really look at spring rates over brand.
Old 06-07-2012, 07:55 PM   #34
TtownMach1's Avatar
Ah thats something I'll have to look into. Don't want to drive holes for the camber plates. Where did you pick yours up at?
Old 06-07-2012, 08:11 PM   #35
silvr002001's Avatar
Re: Which springs?
I have had both eibach pro kit and now the H&R super sports. Pro kit wasnt low enough. Here are the H&R'S
silvr002001 is offline   Reply With Quote
10:33 AM
