Vortec supercharger - Mustang Evolution
Old 06-07-2012, 04:36 AM   #1
Exclamation Vortec supercharger
I have LT, 75mm throttle body, SCT MAF and tuner, 62 lbs injectors and soon a eddy intake. This is the supercharger kit im going to go with, AM doesnt have the kit sorry guys or I would get it from you. What do you think about this kit for my setup?
00-04 Mustang GT V-3 Si-Trim Tuner Kit Satin
This is the other kit:
http://www.summitracing.com/parts/VOR-4FL218-128L/
Not sure if it is inner cooled or not but I can build my on inner cooler cheaper then then kit.
southernstang00 is offline   Reply With Quote
Old 06-07-2012, 09:23 AM   #2
wereKEV's Avatar
Re: Vortec supercharger
MY 06 gt has a vortec v3 sc on it and I have had no proplems with it it was on the car when I bought I dont't know how much boost or hp output on it never had it dynoed.
ID:	53657   Click image for larger version
wereKEV is offline   Reply With Quote
Old 06-07-2012, 10:43 AM   #3
Yeah im def going to go with that type of supercharger....does it have a good whisle to it as it is at idle and when you get on it?
Old 06-07-2012, 05:26 PM   #4
Mmustang01's Avatar
That's a nice kit and the price is even better go for it
01 gt
Procharger d1
Mmr long block
480 rwhp 450 # of torque
Mmustang01 is offline   Reply With Quote
Old 06-07-2012, 09:46 PM   #5
the first kit doesnt include the inner cooler thou....the one from summit does.
Old 06-07-2012, 09:57 PM   #6
Bballing0416's Avatar
That's a great set-up...I have pretty much the same setup and I'm very happy with performance gain.
Bballing0416 is offline   Reply With Quote
Old 06-08-2012, 04:55 AM   #7
Do you have a inner cooler or no ?
Old 06-08-2012, 08:30 AM   #8
No but I plan on getting one in a few months
Old 06-08-2012, 08:34 AM   #9
aw gotcha....guess im just going to get the kit with it. I found the kit I want for 2700 but it doesnt include the intercooler. If it came with the air to water cooler box I was going to build my own but I think I wouldnt say much.
Old 06-08-2012, 08:47 AM   #10
WheelStander's Avatar
Cool I was looking at different chargers too couldn't figure out which one to go with.
I thought I saw something intercooled and cheaper than 3990 at AM for 99 GT No?
How important is ic first off? I would do 2700 then ic a couple months later?
Thanks this will be my first sc car sorry about dumb questions.
Induction: Kenne Bell | wHp: 515 Tq: 503 | 1/4 Mile:11.09@123
WheelStander is offline   Reply With Quote
Old 06-08-2012, 09:06 AM   #11
I didnt see one on AM for under 3990 or at least not the one I want. On my other post someone said a IC is good for more HP and keeping the air cooled and not causing the SC to burn up. Im just going to by the kit because I can do it all at one time. Also, I want one that comes with a blow off valve or bypass value I think that is what the call it .
Old 06-08-2012, 09:13 AM   #12
So basically you shouldn't run without ic?
Old 06-08-2012, 10:54 AM   #13
pretty much...
Old 06-08-2012, 12:29 PM   #14
Ruben3's Avatar
Hey guys I was looking @ the 2700 one and saw it says it doesn't include engine and fuel managment? Does this mean the fuel pump/injector upgrade or something else? Sorry I'm not too experience with this stuff...thnx
Ruben3 is offline   Reply With Quote
Old 06-08-2012, 01:07 PM   #15
correct, its a tuner kit which means it doesnt come with any injectors, pump, and tuner/chip. Since I have my stuff already and im going to run a bigger injector then what it comes with, bigger pump, and a sct tuner. Tuner kits pretty much come with the supercharger and everything you need to install it minus everything you need to get it running, understand?
Old 06-08-2012, 02:02 PM   #16
Thanks
Old 06-08-2012, 02:39 PM   #17
Ruben3's Avatar
Kool...thnx man
01:04 AM
