temperature problems - Mustang Evolution
Old 06-07-2012, 07:48 PM   #1
Hi everybody , need some advice here cause my 94'stang has temperature problems only when I'm stock on traffic or during high temperature days.I change the thermostat,radiator cap and flush all the system already,put new coolant on it,so I'm thinking on a bad fan,but not so sure.If someone can help me it will be very apreciate,thanks.
Savage stallion is offline   Reply With Quote
Old 06-07-2012, 07:49 PM   #2
Put ice on the hood :p lol jk if u changed all the stuff already check the radiator hose that gose into the engine as well as the fan
Mady is offline   Reply With Quote
Old 06-07-2012, 07:52 PM   #3
McNassty's Avatar
Check your oil, is it milky?
McNassty is offline   Reply With Quote
Old 06-07-2012, 08:05 PM   #4
Voltage258's Avatar
Region: Utah
If it does not get hot while you are doing 70mph but it does while your in traffic then u would say your fan. Pop the hood and turn your car on, let it run for a while if it gets hot and your fan never turns on then there is your problem. How long has it been doing it?
If your getting good gas mileage, your not having fun.
Voltage258 is offline   Reply With Quote
Old 06-08-2012, 05:42 PM   #5
Re: temperature problems
Just a few days,I don't ride it often,just for work about 7mins. from home.And yes I had checked oil,don't look bad but will change it next friday.The radiator hose and fan are in turn for checking cause I think the fan is slowing down.Thanks all of you for your help.
Old 06-08-2012, 06:16 PM   #6
FordAddict's Avatar
My radiator had cracked which was my problem. If fan doesn't work then check that.
FordAddict is offline   Reply With Quote
Old 06-08-2012, 07:18 PM   #7
Vegas97gt's Avatar
Region: Nevada
Do you use your ac while you drive can you hear your fan kick on? What color was your coolant when you drained it?
Vegas97gt is offline   Reply With Quote
Old 06-08-2012, 07:43 PM   #8
FordAddict's Avatar
When my car is at idle, how long until the fan kicks on?
Old 06-09-2012, 11:33 AM   #9
Depends on if the car is hott or not...if cold it should kick on as soon as the car reaches the thermostat temp or when the ac is turned on.
Honestly, sounds like to me that the fan isnt either working at all or isnt going fast enough to cool the engine down in other words its not kicking into high speed mode. Also, Im not sure if it was said above but check and see if the rat is stopped up in the front restriciting the air flow at idle or stop.
southernstang00 is offline   Reply With Quote
Old 06-09-2012, 06:34 PM   #10
I'd checked the fan today and don't notice any difference with the engine and a/c workin and with the a/c off.And the fan was at the same speed all the time.
Old 06-10-2012, 02:55 AM   #11
ok, you must have a one speed fan then but somet cars have a two speed fan. If you can remove the fan while the car is cool and take a water hose with a sprayer on it and spray the rat out from the back pushing the water forward. It just might be the fins in the rat are stopped up from debris. Have you put a new thermostat in it?
Old 06-10-2012, 08:00 PM   #12
New thermostat and coolant,I'll remove tha fan for give it a deep clean but I'm getting a new one anyway.Thanks.
Old 06-11-2012, 02:00 AM   #13
so did the new thermostat fix the problem?
05:53 AM
