Underhood - Mustang Evolution
Old 06-08-2012, 05:17 PM   #1
1lowGT's Avatar
Underhood
Anyone ever taken this off and clean/washed it?
Old 06-08-2012, 05:20 PM   #2
351mustanggt's Avatar
pretty sure itd fall apart lol
351mustanggt is offline   Reply With Quote
Old 06-08-2012, 05:24 PM   #3
1lowGT's Avatar
Yeah that's what I was thinking just wandering if there was anyone that has tried Nything
Old 06-08-2012, 07:24 PM   #4
taylor98gt's Avatar
Spray paint it maybe?
taylor98gt is offline   Reply With Quote
Old 06-08-2012, 07:30 PM   #5
Vegas97gt's Avatar
Region: Nevada
I took mine off cleaned and put a coat or 2 of wax on the under side of my hood now you can see my engines reflection you just need a trim popper for the clips and a 8 mm ground bolt
Vegas97gt is offline   Reply With Quote
Old 06-08-2012, 10:20 PM   #6
taylor98gt's Avatar
Can u put up a pic of it?
Old 06-08-2012, 10:30 PM   #7
It's hit or miss whether yours is actually painted underneath. Some are, some aren't. It will generally just fall apart however...
Old 06-09-2012, 09:52 AM   #8
wolfstang03's Avatar
I took mine off and had to paint the hood. Looks a lot better without it imo. I was going to put mirrored Plexiglas in the "triangles " of the underside of the hood, but then after a few years of searching... I found a place that sells them pre-made!
--WOLFSTANG 03--
wolfstang03 is offline   Reply With Quote
Old 06-09-2012, 11:24 PM   #9
1lowGT's Avatar
It does look better but just figured it was there for a reason I'll probably paint the cover thing and judge it from there we will see next week
Old 06-10-2012, 12:41 AM   #10
Vegas97gt's Avatar
Region: Nevada
I think they are there to help the engine warm up faster but I'm not sure and in 110 degree heat you don't need any help
Old 06-10-2012, 04:37 AM   #11
NeedSomeMods's Avatar
Oh?
2000 V6 - RIP
The '94 -
NeedSomeMods is offline   Reply With Quote
Old 06-10-2012, 09:47 AM   #12
1lowGT's Avatar
Lol true true
---------- Post added at 10:47 AM ---------- Previous post was at 10:40 AM ----------
Anyone know what this is called?
Old 06-10-2012, 11:46 AM   #13
MedicDave's Avatar
Doesn't that act like a bit of a heat shield, I would hate to take that out and over time see your paint start to get damaged from all the under hood heat. I may be wrong, I'm going to find out.
MedicDave is offline   Reply With Quote
Old 06-10-2012, 12:02 PM   #14
kjunitalian's Avatar
What i thought too
kjunitalian is offline   Reply With Quote
Old 06-10-2012, 12:43 PM   #15
MedicDave's Avatar
Ok so far I have read that its used as a sound reducer and a heat shield and is fire retardant, the plastic pieces that hold the shield up are supposed to melt causing it to fall over the engine and help to smother a fire,makes sense.
Old 06-10-2012, 04:24 PM   #16
Vegas97gt's Avatar
Region: Nevada
It's called a hood insulator pad
Old 06-10-2012, 04:27 PM   #17
Lorraine's driver
ab_mach1's Avatar
Yup, I'm pretty sure this is in place to keep the heat of the engine away from the paint on your hood.
Instagram: @ab_mach1
Old 06-10-2012, 06:19 PM   #18
Re: Underhood
Ive had mine off for years and never has my engine messed up my paint nor over heated...and its not in any way a sound barrier. I'm sure there is some r eason for it..but nothing that has ever effected my car
--WOLFSTANG 03--
Old 06-10-2012, 11:39 PM   #19
Vegas97gt's Avatar
Region: Nevada
Same here I've had mine off for a few years too and it hasn't messed up my paint either and it gets about 115 out here on hot days on top of driving for 30 to 40 min in traffic and hasn't burned anything yet
Old 06-10-2012, 11:57 PM   #20
Lorraine's driver
ab_mach1's Avatar
Yeah, can't get much hotter than that! That has to beat my theory up.
» Members Mustangs
DW
blue
Mastodon
Mastodon
Add your Mustang
09:55 PM
