Need Help can't drive until fixed! brake light issue! - Mustang Evolution
Old 06-09-2012, 06:53 PM   #1
Topless04GT's Avatar
Hey guys and gals... out of nowhere my brake lights stopped working. Turn signals work, flashers work, just not the brake lights. the 2rd brake light hasnt worked since i bought the new trunk so idk if that one is hot or not. please help!
---------- Post added at 06:53 PM ---------- Previous post was at 06:39 PM ----------
ok so i went under the dash by the brake pedal, checked the two wires from the little box there, and the red/green one is no go. has no power whatsoever... how do I replace this or is it a dealer only thing?
My girl... ehh, cars never leave you! stick to cars!
My name is Josh, Whats yours?
Topless04GT is offline   Reply With Quote
Old 06-09-2012, 06:59 PM   #2
Vegas97gt's Avatar
Region: Nevada
Is it your brake running lights or your when you push on the brakes the light is on
Vegas97gt is offline   Reply With Quote
Old 06-09-2012, 07:11 PM   #3
Devil5711's Avatar
Have u checked the fuse for the brake lights
Devil5711 is offline   Reply With Quote
Old 06-09-2012, 07:22 PM   #4
Re: Need Help can't drive until fixed! brake light issue!
ok now im even more stumped.
it is when i push the brake pedal.
I just checked my fuse box under dash, half of them claim to have no power readings, yet most of them are working ie; cig lighters and so on
wtf is going on!?
Old 06-09-2012, 07:26 PM   #5
It's not me, it's you.
primer2tone's Avatar
Your ****s all ****ed up. Haha, sorry. I can't resist plugging a line from idiocracy.
Old 06-09-2012, 07:30 PM   #6
Devil5711's Avatar
What about the fuse box on the passenger side
Old 06-09-2012, 07:42 PM   #7
02PONY's Avatar
Sounds like the "boo "switch or brake on/off my f150 did this the first week I had it
02PONY is offline   Reply With Quote
Old 06-09-2012, 08:40 PM   #8
lol DICK!
never checked it, on my way out to it now
my thoughts exactly at first, but if one of the wires isn't HOT wouldnt that mean the switch is fine, its just a wire?
Old 06-09-2012, 08:51 PM   #9
Vegas97gt's Avatar
Region: Nevada
Same exact thing happened to my 91 Lincoln taillight running lights but my brake lights worked then my dash lights stopped working. It was my headlight switch I changed that took like 30 min being careful trying not to break anything but that fixed
Old 06-09-2012, 09:48 PM   #10
02PONY's Avatar
So your tail lights are on until u hit your brakes or turn signals then they go out ? Do they come back on when u release pedal? Or trip out until u turn car off and turn back on
Old 06-09-2012, 10:17 PM   #11
car is on + push pedal = no brake lights
car is on + lights on + push pedal = no brake lights
car is on + lights on + turn signals on + push pedal = turn signals flashing, no brake lights
Old 06-10-2012, 06:13 AM   #12
2002VertGT's Avatar
The red/green wire is the break wire if I'm correct and would only have power to it while the break is pressed. Josh, find out what fuse is the break fuse and pull it out and visually check it. If its fine I would check the switch on top of the break pedal. I HIGHLY doubt it is a wire unless you've been messing with wires recently.
4.10 Gear/RPM thread
Old 06-10-2012, 06:48 AM   #13
Snapple750's Avatar
+1
There are 2 fuses for the brake lights; The brake lamps, and the brake switch. Sounds like your brake switch fuse is out.
2 Legit 2 Quit
Snapple750 is offline   Reply With Quote
Old 06-10-2012, 06:52 AM   #14
Cobra Seb's Avatar
Did you chech the bulbs
Cobra Seb is offline   Reply With Quote
Old 06-10-2012, 09:38 AM   #15
2002VertGT's Avatar
Chances of all 6 bulbs ceasing to work are 1 Ina trillion....plus they all light up with turn signal so they are fine.
Old 06-10-2012, 10:22 AM   #16
Devil5711's Avatar
That happened to me i blew the fuse on the passenger side n none of. My lights came on for some safety reason i couldnt get the car out of park till i replaced the switch
Old 06-10-2012, 10:29 AM   #17
Cobra Seb's Avatar
Oh so chances are its probable the brake light switch behind the petal I think
02:19 AM
