T-45 Rattle Help!! - Mustang Evolution
Go Back   Mustang Evolution > 1979-2014 Mustang GT > 1996-2004 Mustang GT
Closed Thread
Old 06-09-2012, 07:42 PM   #1
8111870 is unknown around these parts
T-45 Rattle Help!!
Alright gents, I took the bellhousing off my t45 to replace the bearing retainer that got scarred up by a bad TOB, put it back together, new 03-04 Cobra clutch , flywheel, Ford pilot and TOB Dex/merc111 fluid (3.2l) and there is a rattle/knock at idle! Goes away when i push the clutch or raise rpms above idle.
What could have gotten loose when I removed the bellhousing?
thanks
8111870 is offline
Old 06-09-2012, 07:47 PM   #2
Dancobra75's Avatar
Dancobra75 is unknown around these parts
I know you said you replaced it, but it sounds to me like a throw out bearing, did it seem to fit snug?
Dancobra75 is offline
Old 06-09-2012, 08:04 PM   #3
Re: T-45 Rattle Help!!
TOB moves freely on the shaft. I removed the cable and pushed the bearing away from the PP and the noise is stll there. Conversely I tightened my clutch cable until there was quite a bit of pre-load on the TOB and noise was the same.
It is a rattle with some almost knocking. putting some pressure on the shifter towards gear quietens a bit, leading me to believe it is internal. Tranny was perfect prior so im thinking something got loose.
sorry for the length of the reply!
thanks for all help
8111870 is offline
Closed Thread
12:52 PM
