Cylinder Misfiring? - Mustang Evolution
Old 02-02-2008, 10:28 AM   #1
Cylinder Misfiring?
A couple of weeks ago my 2000 GT Had a Cylinder 8 misfiring and I changed all the Spark plugs and The number 8 Coil on Plug. This week it started the vibration again when it is under stress or has to climb in RPM's I shot the codes again and it said Cylinder 1 and 8 were misfiring this time! Any Ideas on what it may be? or how to fix it?
Jeremym831 is offline   Reply With Quote
Old 02-02-2008, 11:10 AM   #2
MonteCitan's Avatar
Re: Cylinder Misfiring?
Make sure the bores for the coils are clean and dry (when you pull the coils out is there any moisture whatsoever on the boot?)
Beyond that it could be a fuel delivery issue, has he gotten gas at a crappy place lately? might have gummed up an injector or two...
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 02-04-2008, 06:50 PM   #3
Cylinders MisFiring Any Seggestions?
All right so around 3 weeks ago my 2000 GT had a cylinder 8 misfire so I changed all the Spark plugs and the #8 Coil Pak then last week I had a Cylinder 1 and Cylinder 8 Misfire so I changed the number 1 Coil Pak and it fixed that and I swapped the #8 coil pak with the #2 coil pak and still i have a Cylinder 8 misfire but now not only do i have a cylinder 8 misfire on my obd II scanner it also says Random/multiple cylinder misfires any seggestions? I ahve tried everything i know I'm thinking maybe fuel filter but I dont see how that could cause so much trouble. I'm open to any seggestions at this point!!
Old 02-05-2008, 10:42 AM   #4
Re: Cylinders MisFiring Any Seggestions?
Have you replaced the wires??? I know It is a coil over system by your discription but I have experienced in the past that the "wires" do go bad.(that happened to me with an excursion) Those little things that look like spark plug boots have a center core that does go bad. Hope this helps
Truth is Truth whether YOU believe it or not:)
www.bigdmustangs.com
mustero is offline   Reply With Quote
Old 02-05-2008, 12:12 PM   #5
MonteCitan's Avatar
now knowing it says random misfires as well, check the MAF/02 sensors, and fuel pressures...
5.4L Ford GT CYLINDER HEADS EVILUTION GhosT 2005-2010 Mustang GT 2 12-27-2007 05:34 PM
New Cylinder Heads V6Polish Pre-2005 V6 Mustang 5 06-24-2007 01:28 PM
Missfire Cylinder 1 BruThru2002 Pre-2005 V6 Mustang 12 05-15-2007 03:36 PM
92 four cylinder problem Ponyboy86 Pre-2005 V6 Mustang 11 03-23-2005 01:45 PM
cylinder heads. which ones better? rasputinlv Pre-2005 V6 Mustang 11 02-26-2005 11:41 AM
12:38 PM
