Idle prob please help. - Mustang Evolution
Old 06-11-2012, 07:23 AM   #1
Dpsychostang's Avatar
My mustang has been idling rough like sputtering every couple of minutes only when it's in gear and I'm at a stop. Then if I try to accelerate quickly it starts doing the same thing but worst. I thought it was a misfire cause that's what it feels like but it's not throwin any codes for it. What should I do?
Dpsychostang is offline   Reply With Quote
Old 06-11-2012, 08:37 AM   #2
BigB227's Avatar
Try cleaning out or replacing your IAC valve(idle air control valve
BigB227 is offline   Reply With Quote
Old 06-11-2012, 10:59 AM   #3
Just replaced it about two weeks ago. It was doing it before and after I replaced it but the IAC was making a funny humming noise and I couldn't figure it out for a couple months so I had to drive it around like that and I'm wondering if that could have screwed something else up. But now that I replaced it the humming is gone and now it's sputtering at idle and when I accelerate quickly.
Old 06-11-2012, 11:24 AM   #4
Cobra Seb's Avatar
Did you change your positioning sensor
Cobra Seb is offline   Reply With Quote
Old 06-11-2012, 11:29 AM   #5
No I didn't, could that cause the sputter?
Old 06-11-2012, 11:34 AM   #6
Lorraine's driver
ab_mach1's Avatar
Venomouz831 had some idle issues and found his prob to be a vacuum leak. He had a crack in one of the hoses. You might look in that direction. Could be small enough that when your moving the vacuum increases enough to remedy the prob, till you stop and idle.
Instagram: @ab_mach1
Old 06-11-2012, 11:36 AM   #7
Eturner's Avatar
Do you have a tune put in your car?... If so make sure (don't remember what it's called off hand, brain fart), the ECU part for throwing codes is turned on!.. Because if it's off, then something can go wrong with your car and it won't throw any codes!..
Old 06-11-2012, 01:26 PM   #8
Would that cause it to sputter when I accelerate quickly? When I drive like an old lady its fine. Lol
---------- Post added at 12:26 PM ---------- Previous post was at 12:25 PM ----------
No tune in the car that I know of.
Old 06-11-2012, 01:40 PM   #9
Lorraine's driver
ab_mach1's Avatar
For my car, it was the COP's (coil on plug). One was not seated all the way. But I was getting CEL with a misfire code. There is a number of things it could be. I'd start with the easy stuff like...
bad gas
vacuum leaks
bad spark plugs (but could still be spark, just not good)
fuel filter (ever changed?)
fuel pressure (press to low?)
Maybe some others could help with emissions level stuff that could cause this?
Hope that helps!
Old 06-11-2012, 01:43 PM   #10
Eturner's Avatar
bad gas
vacuum leaks
Hope that helps!
+11 seeing as you don't have a tune this is a good list to start with!..
Old 06-12-2012, 08:47 AM   #11
bad gas
vacuum leaks
Hope that helps!
Thanks for the advice bro, at this point I'll try anything.
Old 06-12-2012, 09:26 AM   #12
garbill2003's Avatar
Hey try taking off negative battery terminal for 10 to 15 minutes for the computer to reset then put it back on and drive it see what happens and let us know
garbill2003 is offline   Reply With Quote
Old 06-12-2012, 09:59 AM   #13
I did the idle relearn, disconnect neg for 30 mins let engine get up to temp turn ac on max for one minute then drive for about ten miles but it didn't help, not sure if it even works for my year.
Old 06-12-2012, 10:02 AM   #14
Lorraine's driver
ab_mach1's Avatar
99 on up, I think.
Old 06-12-2012, 10:03 AM   #15
99 on up, I think.
That's what I heard I got a 98 go figure.
Old 06-12-2012, 10:03 AM   #16
Ok I would visually inspect it then vacuum hoses take out a plug or two check their condition do a fuel pressure check clean throttle body mas meter simple things before you dump wads of cash into it just my opinion
Old 06-12-2012, 10:08 AM   #17
Eturner's Avatar
Personally I would pull all the plugs and check them all!.. Besides it only takes a couple of minutes to go through them all!..
Old 06-12-2012, 10:11 AM   #18
I agree they will tell you each cylinders picture
Old 06-12-2012, 10:11 AM   #19
Lorraine's driver
ab_mach1's Avatar
+1, and it only takes one to give you probs
Old 06-12-2012, 10:39 AM   #20
I would love to but I can't get one out. The eighth plug by the firewall on the passenger side shot outta the block one day and stripped it, I had to get a helix coil on it now it won't come out.
Old 06-12-2012, 10:43 AM   #21
Lorraine's driver
ab_mach1's Avatar
You must have a spank load of detonation going on there. Hopefully a defective plug, but that's rare these days. Working on that prob should be your goal. She won't run right until that is resolved.
Old 06-12-2012, 11:00 AM   #22
Eturner's Avatar
Have you pulled the other plugs yet?.. And how did they look?..
---------- Post added at 10:00 AM ---------- Previous post was at 10:00 AM ----------
+11
Old 06-12-2012, 11:24 AM   #23
+11
I pulled a couple and replaced a few that looked bad. If I'm not throwin a code for a misfire could it still be the plugs?
Old 06-12-2012, 11:35 AM   #24
Eturner's Avatar
It possible!.. I would go ahead and pull the others that you can get out and check them!.. Then work on that last one!..
Old 06-15-2012, 08:47 AM   #25
The last plug shot outta the block on my way to work yesterday, lol So I had the shop put the new plug in and a new helix coil. She runs great now, I'm so stoked I just wanna drive it for no reason just to get on it and feel that power again. Ok I'm back from mustang fantasy land lol, It was definitely the plugs. Thanks for everybody's help.
Old 06-15-2012, 08:57 AM   #26
Lorraine's driver
ab_mach1's Avatar
That's great! Glad your running solid. And I just like to drive mine for no reason too!
05:04 AM
