Tranny Problems - Mustang Evolution
Old 06-11-2012, 11:07 PM   #1
jshetler122's Avatar
Tranny Problems
Hey I have a 97 Mustang GT 5 speed that I recently put a clutch and of course as well as the pilot and throw out bearing in and it was fine for a while, but here recently any back pressure on the transmission such as reverse or downshifting it makes like a vibration/rubbing noise. I talked to somebody and he seemed to think it was a bearing. Any ideas on what my problem could be and the price?
Thanks
jshetler122 is offline   Reply With Quote
Old 06-12-2012, 12:31 AM   #2
Vegas97gt's Avatar
Region: Nevada
What do you mean is it like a grind or chirp noise? Is it hard to go into gear? Is it the trans vibrating? How did your mount look? Is it when your foot is on the clutch?
Vegas97gt is offline   Reply With Quote
Old 06-12-2012, 01:46 PM   #3
Matticus's Avatar
I have a similar problem with 4th gear. If I don't hit it just right, it'll grind and spit it back out into neutral lol.
Matticus is offline   Reply With Quote
Old 06-12-2012, 03:29 PM   #4
taylor98gt's Avatar
Mine does the same thing going into 4th and reverse. Syncros I guess?
taylor98gt is offline   Reply With Quote
Old 06-12-2012, 05:01 PM   #5
Matticus's Avatar
That's what I'm thinking
Old 06-14-2012, 02:42 PM   #6
trejo_03's Avatar
What or were exactly would that be in the tranny I think that might be what's wrong with my 03 gt it only scratches in 3rd and 4th and some times gets stuck in reverse could that be it?
trejo_03 is offline   Reply With Quote
Old 06-14-2012, 03:51 PM   #7
LAS97GT's Avatar
It is. Am about to buy a high end T-bearing. Will change clutch later when I have more HP.
---Las97GT
Old 07-11-2012, 10:32 PM   #8
Re: Tranny Problems
its a tranny mount and throwout bearing even tho i just replaced it
Old 07-14-2012, 03:22 PM   #9
LAS97GT's Avatar
Just figured it out that after market clutch plates are whack no matter what you do. When tehy heat up they glaze then slip causing shudder. High end TOB don't help. I tried it like I planned above. Will do a clutch upgrade when I install PI heads.
With the T45, I changed to RP. Now it glides, but rear end needs rebuild too. Essentially, short cutting drive train performance on an older car is well, useless. I plan on building from rear to front.
---------- Post added at 04:22 PM ---------- Previous post was at 04:12 PM ----------
Reference is made to stock clutches. Not high performance, dependable clutch kits.
---Las97GT
Old 07-14-2012, 04:10 PM   #10
Lorraine's driver
ab_mach1's Avatar
Re: Tranny Problems
I would definately check the mounts first. Since it was just worked on, could simply be that they were not tightened properly. It could be jumping around when you downshift or go into reverse.
Instagram: @ab_mach1
02:37 AM
