Need help!!!!!!! - Mustang Evolution
Old 06-12-2012, 07:05 PM   #1
Need help!!!!!!!
K so I got the new CAI from American muscle, and forgot to plug the MAF sensor back in and drove it to the hardware store to plug up the hole ment for the v6 (damn sixers!) so anyway the check engine light came on, any words of advice people?
Mady is offline   Reply With Quote
Old 06-12-2012, 07:08 PM   #2
Buy a Bama programmer to shut it off.
Ryan7racin is offline   Reply With Quote
Old 06-12-2012, 07:09 PM   #3
What exactly happened though?
Old 06-12-2012, 07:15 PM   #4
Lorraine's driver
ab_mach1's Avatar
Plug the connector from the harness for the MAF back into the MAF. The check eng light should go away.
Instagram: @ab_mach1
Old 06-12-2012, 07:15 PM   #5
Siendly22's Avatar
[QUOTE="Mady"]What exactly happened though?[/
Remove your negative terminal on the battery for 15 to 20 mins then put it back.. I hope it helps
Siendly22 is offline   Reply With Quote
Old 06-12-2012, 07:17 PM   #6
I did both of what you both said and the check engine light is still on damn
Old 06-12-2012, 07:20 PM   #7
taylor98gt's Avatar
Whenever mine comes on for a o2 sensor or anything I Jus unhook the negative side for bout a hour and it goes off
taylor98gt is offline   Reply With Quote
Old 06-12-2012, 07:22 PM   #8
Maybe the CAI requires a tune?
Old 06-12-2012, 07:23 PM   #9
Siendly22's Avatar
Just remove the negative terminal for a while an hour or two. Dont panic lol
Old 06-12-2012, 07:24 PM   #10
No you shouldn't need a tune. Mine did this on my f150 I just hooked it back up and it went away. On my mustang it wouldn't go away cause of the o2 sensors I got tired of seeing it bought a Bama programmer and it's gone!
Old 06-12-2012, 07:25 PM   #11
Siendly22's Avatar
Not necessary , I install my K&N CAI without tune woks fine. No check engine light . Then the following month I tune my car.
Old 06-12-2012, 07:29 PM   #12
I see well I basically have a cold air intake and magma flow mufflers what next?
Old 06-12-2012, 07:31 PM   #13
Siendly22's Avatar
Change your throttle body 75mm . You will thank me lol
Old 06-12-2012, 07:33 PM   #14
Damn u all now I want engine mods! Granted my CAI was a pain to put in but that's partly due to buying the project kid from AM
Old 06-12-2012, 07:45 PM   #15
2000_gt's Avatar
Unplug negative battery cable for about 10-15 mins and plug your sensor back in then reconnect
2000_gt is offline   Reply With Quote
Old 06-12-2012, 08:52 PM   #16
Lorraine's driver
ab_mach1's Avatar
Since you need to reset your ECU, you might as well complete the idle re-learn...
Disconnect NEG from battery for 30min
Reconnect and start car, let idle as eng gets to operating temp. Let it idle a little over a minute
Turn on A/C to MAX, let idle little over a minute, turn off A/C
Then drive the car for at least 10 miles
Now you'll have a smooth idle to go along with your new CAI
Old 06-12-2012, 10:26 PM   #17
Vegas97gt's Avatar
Region: Nevada
Is the check engine light still on? If so check your plugs when I did the one on my dads car it came with an extension and the prong to the extension was broken so it kicked the cel on luckily the plug reached without the extension. If that doesn't work take to an autoparts store that does free scans so you know what the reading is
Vegas97gt is offline   Reply With Quote
07:22 AM
