Lifter - Mustang Evolution
Old 06-16-2012, 02:03 PM   #1
2000_gt's Avatar
Lifter
Can anyone explain how to replace lifters and what I'll need to do it with.
2000_gt is offline   Reply With Quote
Old 06-17-2012, 09:07 PM   #2
32vNomad's Avatar
Re: Lifter
Why are you replacing lifters? Follow the link below it will take you to the tool you will need.
---------- Post added at 10:07 PM ---------- Previous post was at 09:55 PM ----------
Total Engine Airflow | Custom Cylinder Head Assemblies Tallmadge | Airflow Development | Custom Cylinder Head Ohio | TEA Total Engine | CNC Porting | Cylinder Heads | Cylinder Head CNC Porting | Ohio | :: Total Engine Airflow ::
32vNomad is offline   Reply With Quote
Old 06-17-2012, 11:20 PM   #3
2000_gt's Avatar
I have one bad and it ticks
Old 06-18-2012, 03:04 PM   #4
32vNomad's Avatar
Re: Lifter
What oil are you running? Also mod motors do have a tendency to tick, but are you sure its not an injector? The link that I put in the last post with take you to the tool that you need. You have to remove the followers and then you can just take out the lash adjusters (lifters). Just a little learning session, the term lifters is not correct in a OHC setup up since they do not lift, they are they to take up slack from the followers. So with that tool you should be able to remove what you need to get to.
Old 06-18-2012, 03:42 PM   #5
2000_gt's Avatar
Valveoline synthetic and I had it checked and they told me the 4.6 was bad about doing it and it's stock with a o/r xpipe. Ford place estimated $1,053 for everything another place said 400 for labor so I'm prolly going 400 an going to do something else to make up for the other $500 inside like rocker arms or something and suggestions
Old 06-18-2012, 03:43 PM   #6
LAS97GT's Avatar
Heard that before about lifters on OHC.
---Las97GT
Old 06-18-2012, 03:44 PM   #7
2000_gt's Avatar
For performance gains on suggestions
Old 06-18-2012, 03:46 PM   #8
LAS97GT's Avatar
I use Mobil 1 5W20 syntech weight now. C-shaft oil seals stopped leaking too. Will never use other oils.
---Las97GT
Old 06-18-2012, 03:48 PM   #9
2000_gt's Avatar
I use 5w20 also but Valveoline
10:15 AM
