LT headers help - Mustang Evolution
Old 06-20-2012, 09:49 PM   #1
Venomouz831's Avatar
LT headers help
So I got a guy that will install the headers next Wednesday. I have a couple questions do I need new gaskets or bolts or do I need to buy some new ones. And on the midpiped tht I have there is an empty hole for a plug I'm guessing and o2 but was wondering if the one already on my bassani x pipe will do or if I need to buy a new one.
)02 Gt, Founder of WE2G
Old 06-20-2012, 10:15 PM   #2
gqsmash's Avatar
Your headers should come with Gaskets and bolts...when I did mine I was recommended to spray the gasket with copper coat and I'm sure others will tell you too. And your o2 should fit
gqsmash is offline   Reply With Quote
Old 06-20-2012, 10:31 PM   #3
Well I bought them used. So I guess I have to buy new ones
Old 06-21-2012, 01:03 AM   #4
So should I order some gaskets online or can I get them like at napa or something?
Old 06-21-2012, 01:16 AM   #5
TtownMach1's Avatar
When I installed my headers I used the gaskets and bolts that was supplied with my kit. Unfortunately didn't have the best of luck the first go around. (had exhaust leak bad gasket, bolts backing out). Look into FRPP gaskets, and maybe some stage 8 locking bolts. Worth the money to not have to go back and redo IMO. Hope this helps.
5-Speed-IUP, Predator tuned, k&n cai,Mrt shifter,Hooker Lts-o/f x-pipe, KC clutch,Alum flywheel,FR 4:10's. Upr rear control arms. Forged Teksid Eaton swap in progress!
WickedStangs Mustang Club
Tulsa,OK Chapter President
TtownMach1 is offline   Reply With Quote
Old 06-21-2012, 01:20 AM   #6
Yea this def helps. I'll check those out tmrw thnks. I just was wondering if I was able to use the stock gaskets n bolts
01:37 AM
