Grinding - Mustang Evolution
Old 06-22-2012, 08:36 PM   #1
Matticus's Avatar
Grinding
So I've had a problem with my 4th gear grinding and spitting back out into neutral every now and then for a while, wasn't a big deal. On my way home, it did it really bad, worse than ever. It shook the whole car and I almost pulled over. I've been told its a synchronizer issue, but I'm not very knowledgeable when it comes to transmissions. I just know I need to get this fixed before it gets any worse. Any input/suggestions on the problem and what kind of costs I'm looking at? I'd greatly appreciate any help I can get, thanks.
Matticus is offline   Reply With Quote
Old 06-22-2012, 09:12 PM   #2
Illdrag's Avatar
Synchro's. It'll run ya anywhere from $450- 600 if you take the trams to em, looking at $1500 or better if being the car..
Illdrag is offline   Reply With Quote
Old 06-22-2012, 11:33 PM   #3
Matticus's Avatar
Anyway it can be fixed at home? I have a buddy who has a shop with a lift and they do a lot of stuff on their own
Old 06-22-2012, 11:38 PM   #4
Illdrag's Avatar
Yea it can be done at home, wit the right tools and the right knowledge.. If your friend has no experience in manual transmission rebuild, I highly recommend sending the trans out to your local trans specialist
Old 06-22-2012, 11:43 PM   #5
Matticus's Avatar
He built a fox body with about 1k hp and has several other mustangs, I'll ask him about it, I just wasn't sure how big of a job it would be
Old 06-23-2012, 01:22 AM   #6
Matticus's Avatar
I've got 160k miles, you think I should just rebuild the whole transmission, or just do the 4th sync?
Old 06-23-2012, 01:38 AM   #7
Lorraine's driver
ab_mach1's Avatar
I'd definitely check the cost for both. If you can swing it, I'd try for a full rebuild. Do at least stock clutch and supporting cast as well. Maybe your bud can let you help to cut the cost of the rebuild. You could try changing the tranny fluid and see if that helps. Don't use synthetic ATF like Royal Purple cause I hear it's bad for the synchros. I think Ford has a Mercon V ATF now.
Instagram: @ab_mach1
Old 06-23-2012, 06:51 AM   #8
It's not me, it's you.
primer2tone's Avatar
This thread has a misleading title. I'm so disappointed. It's a freakin sausage fest in here. Fail! Lol
Old 06-23-2012, 07:45 AM   #9
Lorraine's driver
ab_mach1's Avatar
Lol^
Old 06-23-2012, 08:41 AM   #10
95v686gt's Avatar
He got all excited for nothing lol
1995 V6 Mustang= Divorced Duals, Flowmaster 2 chambers, NO CATS, Raxiom Halo Projector headlights, Smoked Tails, 17 inch Bullitt Wheels
1997 Mustang GT: 4.6L DOHC http://www.mustangevolution.com/forum/f280/t305270/
1986 Mustang GT= Built 302 SOLD
95v686gt is offline   Reply With Quote
Old 06-23-2012, 08:49 AM   #11
ID:	56056There, now we're all excited! LMAO!
Old 06-23-2012, 08:50 AM   #12
95v686gt's Avatar
Lmao she can grind my gears!!!!
Old 06-23-2012, 06:01 PM   #13
Matticus's Avatar
Any other relative input?
---------- Post added at 07:01 PM ---------- Previous post was at 07:00 PM ----------
Relevant*
Old 06-23-2012, 10:56 PM   #14
Illdrag's Avatar
Buddie I'm tellin you that's it, worst case 4 gear
---------- Post added at 10:56 PM ---------- Previous post was at 10:54 PM ----------
Is toast but you got it a part it's just $100 part, labor shouldn't change
Old 06-23-2012, 11:25 PM   #15
Matticus's Avatar
Didn't mean to sound unappreciative lol, I just wanna get all the info I can before I start pulling out my transmission and throwing money around haha.
Old 06-23-2012, 11:39 PM   #16
Lorraine's driver
ab_mach1's Avatar
Cheapest start would be to change the fluid. Always start with the simple first. The TR-3650 tranny has finicky synchros anyway. Dump some fresh Mercon V ATF in there and see what happens then go from there.
Old 06-23-2012, 11:44 PM   #17
Matticus's Avatar
Alright, I've also read that a stretched clutch cable can cause problems like that. How do you go about checking that?
Old 06-24-2012, 12:21 AM   #18
Lorraine's driver
ab_mach1's Avatar
You could get on the highway and go the speed limit. Maintaining steady speed, push your clutch in slowly. It should start to slip the clutch after about 3/4 to 1 inch from fully out. If you can move it more than an inch before the clutch starts to slip, then it may need adjusting.
The other test I've heard but have not done is to go to a parking lot where there is nothing in front of you. Put the tranny in 5th and with the parking brake ON, pop the clutch. If you engine doesn't die immediately, your clutch is starting to die.
05:16 PM
