HELP - Mustang Evolution
Old 06-26-2012, 09:42 PM   #1
FORDuhl6's Avatar
HELP
I bought my car with a
Procharger
Intercooler
Headers
Blah blah blah
It has a stock throttle body. I have a chance to get a BBK 75mm and was wondering how much of a difference this would make?
How easy is install?
Is it worth me buying it.
Thanks guys!
FORDuhl6 is offline   Reply With Quote
Old 06-26-2012, 10:04 PM   #2
BigB227's Avatar
Procharger
Intercooler
Headers
Blah blah blah
Thanks guys!
Well since your FI the 75 will be alot better over stock and you will really feel the difference in pickup and throttle.
I would say get it but is it just the throttle body or is it the plenum also? If its just the throttle body your better off getting a throttle body plenum combo
BigB227 is offline   Reply With Quote
Old 06-26-2012, 10:15 PM   #3
FORDuhl6's Avatar
It's just the TB but I can get it from my little brother for next to nothing. How hard is install guys?
Old 06-26-2012, 11:50 PM   #4
Re: HELP
its simple to install...four bolts, the spring, throttle cable and TPS ( if not equipped with it) You will just have to take the intake pipe off the Throttle body. Its easy nothing to it, if you can change you own oil you can do this.
southernstang00 is offline   Reply With Quote
Old 06-27-2012, 08:24 AM   #5
FORDuhl6's Avatar
Thanks. I'll do it in a couple days. Would I need a new tune for this mod?
Old 06-27-2012, 08:41 AM   #6
Re: HELP
umm...I say yes only because there is more flow of air into the engine esp with your supercharger or at least I would get another one just in case.
Old 06-27-2012, 08:44 AM   #7
FORDuhl6's Avatar
I dot have the ah now but after I do it I'll save up for it.
Old 06-27-2012, 09:05 AM   #8
Eturner's Avatar
Just save up the cash and get the 78mm TB Plenum from BBK!.. It's one whole piece and will cost about ad much!..
Old 06-27-2012, 09:08 AM   #9
Lorraine's driver
ab_mach1's Avatar
Since he has a supercharger, should he go for a little bigger injectors to go along with the TB upgrade?
Instagram: @ab_mach1
Old 06-27-2012, 09:21 AM   #10
FORDuhl6's Avatar
I have bigger injectors already. Sorry forgot to say that.
Old 06-27-2012, 09:41 AM   #11
Lorraine's driver
ab_mach1's Avatar
Cool! I would think a TB would do a lot for your car because of the SC. You already have modded your exhaust so now you can accept more air. Most likely will want a tune to make sure you don't detonate or run lean. southernstang00 may have some more to add to this, but I think this is right.
Old 06-27-2012, 09:43 AM   #12
FORDuhl6's Avatar
Thanks guys
Old 06-27-2012, 11:04 AM   #13
Re: HELP
Correct, most of the time if you make big changes like going from stock TB to a bigger one its a good idea to get it changed in the computer or tuned. You def want to do this when changing injectors, I saw a article the other day in a magazine saying that if you change all three CAI, TB, and plenium its best to get a tune because of the more air into the engine even if it is running ok.
Old 06-27-2012, 11:19 AM   #14
You don't need a tune for it but to get all the benefits from it you should get one.
I ran my car without a tune with full bolt on including a 70mm throttle body combo with plenum and it was fine but just got the SCT tuner with custom tunes and it really wakes it up you get a lot more out the mods.
Hope I helped out.
Ryan7racin is offline   Reply With Quote
Old 06-27-2012, 12:10 PM   #15
FORDuhl6's Avatar
Hope I helped out.
Thanks
02:09 AM
