Quuestion - Mustang Evolution
Old 06-27-2012, 07:49 PM   #1
nathan2393's Avatar
Quuestion
I have a 03 mach 1 and I straight pipped it and now it has a bogging problem because the back pressure would 12 inch cherry bombs fix it?
nathan2393 is offline   Reply With Quote
Old 06-27-2012, 08:03 PM   #2
Mile high JDF's Avatar
Um adding a muffler creates more backpressure.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 06-27-2012, 08:08 PM   #3
nathan2393's Avatar
I no that but will a cherry bomb be enough
Old 06-27-2012, 08:09 PM   #4
Shelby09's Avatar
I bet that joker is louf
---------- Post added at 10:09 PM ---------- Previous post was at 10:09 PM ----------
Loud*
Shelby09 is offline   Reply With Quote
Old 06-27-2012, 08:09 PM   #5
Is it bogging because of the lack of backpressure?
Old 06-27-2012, 08:11 PM   #6
Shelby09's Avatar
Most likely
Old 06-27-2012, 08:12 PM   #7
Eturner's Avatar
Your cars "bogging problem" is do to some thing else!.. You have no back pressure because of your straight pipes!.. Perhaps you need to adjust your tune or get a tuner for it!..
Old 06-27-2012, 08:17 PM   #8
nathan2393's Avatar
So would cherry bomb be enough back pressure? Or a waste of money cause I want it to be loud and run right
---------- Post added at 08:17 PM ---------- Previous post was at 08:16 PM ----------
I wanna get a tuner but I wanna wait and go with something cheaper for now
Old 06-27-2012, 08:17 PM   #9
Shelby09's Avatar
Just buy a tuner if u like the way it sounds.. That will fix ur bog
Old 06-27-2012, 08:18 PM   #10
nathan2393's Avatar
What tuner would you recommend thats not to pricey
Old 06-27-2012, 08:18 PM   #11
How did you come to the conclusion that the straight pipes are the reason you're bogging?
Old 06-27-2012, 08:19 PM   #12
Shelby09's Avatar
I have an sct tuner.. Worth the money
Old 06-27-2012, 08:20 PM   #13
+1
Old 06-27-2012, 08:21 PM   #14
Eturner's Avatar
+11. 0 back pressure = better performance!..
Old 06-27-2012, 08:23 PM   #15
Shelby09's Avatar
The car was built from the factory to have back pressure.. When u remove every restriction on the exhaust it's not going to run the way it was programmed to run.. Needs a re tune
Old 06-27-2012, 08:24 PM   #16
Eturner's Avatar
Getting a different muffler is going to do nothing for ya but change how it sounds!.. Save your cash up and get a tuner!.. Diablo or SCT are good choices!..
Old 06-27-2012, 08:30 PM   #17
nathan2393's Avatar
Alright I will and I came to that conclusion just from different muffler people and ok I will get the tuner
Old 06-27-2012, 08:30 PM   #18
Eturner's Avatar
Not really true!.. I have a buddy with full exhaust and other bolt ons with no tune at all!.. Runs just fine!.. The back pressure is a side effect from the factory having to meet certain emissions and sound restrictions from the factory!..
Old 06-27-2012, 08:31 PM   #19
Which is why the computer is there to sense changes in the A/F ratio. Removing the mufflers isn't gonna create so much of an increase in airflow that the computer can't handle it.
Old 06-27-2012, 08:32 PM   #20
Shelby09's Avatar
Running fine and running to its fullest potential are 2 diff things...
Old 06-27-2012, 08:36 PM   #21
Eturner's Avatar
Check out AM and BAMA!.. They seem to be running some good deals!.. I got a Diablo Sport Predator but that was 5 years ago!..
---------- Post added at 08:36 PM ---------- Previous post was at 08:32 PM ----------
All the more why his car shouldn't be bogging!.. Lol.
Old 06-27-2012, 08:41 PM   #22
Shelby09's Avatar
Ok.. Not back pressure what's the other problems?? What fuel u running? Bad fuel? Clogged air filter? Clogged fuel filter?
Old 06-27-2012, 08:46 PM   #23
nathan2393's Avatar
Exactly I want it running at its best
---------- Post added at 08:46 PM ---------- Previous post was at 08:44 PM ----------
I was told the fuel pump could be a problem but you should be able to here it then when you start up the car but I run 91
Old 06-27-2012, 08:48 PM   #24
Shelby09's Avatar
I run 93 all the time.. Only from shell
Old 06-27-2012, 08:50 PM   #25
It could sill be the problem. If its not delivering as much fuel as it should be that could cause you to bog
Old 06-27-2012, 08:52 PM   #26
Shelby09's Avatar
Do the pumps say that the has could have certain percent ethanol?
Old 06-27-2012, 08:55 PM   #27
nathan2393's Avatar
It has to be 91 its on the car and can't I check the fuel pressure to see if its the pump?
Old 06-27-2012, 08:56 PM   #28
2000_gt's Avatar
Sure can
2000_gt is offline   Reply With Quote
Old 06-27-2012, 09:00 PM   #29
nathan2393's Avatar
Alright but if its not that what else could it be?
09:36 AM
