car questions - Mustang Evolution
Old 07-02-2012, 11:31 AM   #1
kell97Gt's Avatar
car questions
Wen i did my tune up i noticed tht my spark plug butts were covered in oil three plugs .....O also my check engine light doesnt come on and my odemeter stop spinin.....im lost how do i fix the last two
kell97Gt is offline   Reply With Quote
Old 07-02-2012, 02:32 PM   #2
1slosix's Avatar
Re: car questions
The last two could be fuse related...the first seems like a cracked gasket
Old 07-02-2012, 02:46 PM   #3
kell97Gt's Avatar
On da fuzes i checked the one under the stearing colume and cracked gasket ....thanks any ideas wat gasket
Old 07-02-2012, 02:48 PM   #4
1slosix's Avatar
Re: car questions
Head gasket most likely...but probably a small one if you just onlu noticed oil while doing plugs and not from smoke out the back...might try some head gasket sealer since it seems small
Old 07-02-2012, 03:16 PM   #5
kell97Gt's Avatar
Thankz man
---------- Post added at 04:16 PM ---------- Previous post was at 04:12 PM ----------
Is it worth anything tho im plannin on buildin my car up is it guna mess anything up
Old 07-02-2012, 03:20 PM   #6
1slosix's Avatar
Re: car questions
Id rather fix it now then it get worse later
Old 07-02-2012, 05:36 PM   #7
kell97Gt's Avatar
Thank you
Old 07-03-2012, 12:51 AM   #8
TopgearGT's Avatar
Re: car questions
+1 problems always get worse then end up costing as much as that new mod you were planning on investing in! I hate when stuff like that happens!
http://www.mustangevolution.com/forum/users/25023-albums2837-17413.jpg
CSVT and 02 GT!
TopgearGT is offline   Reply With Quote
Old 07-03-2012, 02:51 AM   #9
kell97Gt's Avatar
Good lookin out
Old 07-03-2012, 09:22 AM   #10
95v686gt's Avatar
9 times out of 10 a cracked "gasket" would be water in the cylinders not oil. Oil in the cylinders could be from worn out valve seals pcv system sucking oil into the intake or possible worm out piston rings. As for the odometer the sn95 dashes are known for the gears in them breaking. The CEL light could be that someone pulled the bulb out of it in the dash. I'd take it to a shop an see if they can pull codes from the ECM.
1995 V6 Mustang= Divorced Duals, Flowmaster 2 chambers, NO CATS, Raxiom Halo Projector headlights, Smoked Tails, 17 inch Bullitt Wheels
1997 Mustang GT: 4.6L DOHC http://www.mustangevolution.com/forum/f280/t305270/
1986 Mustang GT= Built 302 SOLD
95v686gt is offline   Reply With Quote
Old 07-03-2012, 03:36 PM   #11
kell97Gt's Avatar
....THANKZ
---------- Post added at 04:36 PM ---------- Previous post was at 04:29 PM ----------
The crazy thing wen i got the car i noticed sum weird things i had a chunk of cast iron in my tranny tht mess wit my forks and sand in my radatior im goin all out wit my baby im jus tryna get some realistic ideas she will be build
Old 07-03-2012, 04:05 PM   #12
95v686gt's Avatar
Sand in the radiator sounds like somebody did blow a head gasket and dumped block sealer in it...
Old 07-03-2012, 04:14 PM   #13
kell97Gt's Avatar
......wow
06:16 AM
