CEL - Mustang Evolution
Go Back   Mustang Evolution > 1979-2014 Mustang GT > 1996-2004 Mustang GT
Closed Thread
Old 07-02-2012, 02:10 PM   #1
charlie03fastGT's Avatar
charlie03fastGT is unknown around these parts
CEL
Got these codes P0171 and P0174 any ideas what's causing it to run lean?
charlie03fastGT is offline
Old 07-02-2012, 02:14 PM   #2
1slosix's Avatar
1slosix is just getting started.
Re: CEL
Vacuum leak or gasket leak since both are flashing up...if it was just one or the other id say either leak or faulty sensor
1slosix is online now
Old 07-02-2012, 02:17 PM   #3
That's my thought cuz the intake manifold just got replaced.
Old 07-02-2012, 02:21 PM   #4
1slosix's Avatar
Re: CEL
Id check the gasket ...or was this code flashing before the replacement happened? Did your old intake crack?
Old 07-02-2012, 02:24 PM   #5
Yes my old one cracked. The light came on like 75 miles after putting the new one on.
Old 07-02-2012, 02:30 PM   #6
1slosix's Avatar
Re: CEL
Hmm if it cracked between drive cycles that can explain away the delayed light. Pull the battery for 15 minutes to reset the live data....drive it and see if the lights comes on and stays on after about 75 miles. If it does have it retested and see if the code is the same or shifted
Old 07-02-2012, 04:50 PM   #7
Ima vacuum test it tommorrw and go from there.
Closed Thread
07:10 AM
