hey guys - Mustang Evolution
Go Back   Mustang Evolution > 1979-2014 Mustang GT > 1996-2004 Mustang GT
Closed Thread
Old 07-03-2012, 05:08 PM   #1
kid_kash_00 is unknown around these parts
hey guys
im new to the 4.6 ive owned 5.0 for a while never the 4.6 i just swapped the modded 5.0 for a stock 96gt for the wife and i think it has a cracked head lol it misses looses a lt of water with no leaks and has no power lol but its not bad loking anybofy kw anything bout these please help thanks
kid_kash_00 is offline
Old 07-03-2012, 05:58 PM   #2
Blog Manager
Blogger
Lalayla is unknown around these parts
Welcome
Lalayla is offline
Old 07-03-2012, 11:02 PM   #3
Mathew r Wright's Avatar
Mathew r Wright is unknown around these parts
Originally Posted by Lalayla
Welcome
Yes welcome, sorry but no advise on your sounds to be problem though...
Mathew r Wright is offline
Old 07-03-2012, 11:05 PM   #4
Blog Manager
Blogger
Sorry thought this was intro section. No advice on the problem but I'm sure someone will chime in
Lalayla is offline
Old 07-03-2012, 11:16 PM   #5
Do The Evolution
primer2tone's Avatar
primer2tone is unknown around these parts
If its losing coolant but not leaking on the ground there's only two other places it can go. It's either leaking into your oil pan or out your tail pipe. Have you checked your oil level? Does the car blow white smoke out of the exhaust?
primer2tone is offline
Old 07-04-2012, 12:02 AM   #6
CrookedHalos's Avatar
CrookedHalos is unknown around these parts
I used to have a Cavalier that the coolant would boil and dry out due to a hole somewhere in the system. The engine got hydro locked before I ever found it. Maybe it can be a similar problem? Just be careful driving it. I had no choice cuz I was a delivery guy. Lol had coolant shooting out from the cracks of my hood like it was a NOS purge.
CrookedHalos is offline
Old 07-04-2012, 03:42 AM   #7
southernstang00 is unknown around these parts
Re: hey guys
The only advice I can give you if you think its a cracked head is start the car let it run for about three mins and cut it off. This doesnt allow the engine to get too hott to evap the coolant off the cyn if it is leaking in there. This allows the water pump to move the water around building up some pressure to see if it is leaking into the cyn. Pull the spark plug out and shine a flash light down in the spark plug hole at the same time looking down there to see if you see water on the cyn. If the cyn isnt at top dead center or you can't see it then have someone with a socket turn the crank until it comes up to where you can the cyn.
Most of the time if water is getting into the cyn you will see the evidence by just looking at the spark plug it will tell you alot.
The other way is just to pull the heads if you think its cracked and have them checked out.
southernstang00 is offline
Old 07-04-2012, 05:47 AM   #8
onesickstang01's Avatar
onesickstang01 is unknown around these parts
The 96 is known for head gasket issues. Not because of the motor itself but because they had a very small radiator that just could t hold up to the job. If you are losing coolant and its not on the ground then you have a head gasket issue. Its not a fun job. Shop labor time is about 10hrs. You need new head gaskets and head bolts along with all the other upper motor gaskets. You will need to remove the timing chains so will have to know how to at least mark timing to put it back dead on. These are interference motors so timing has to be spot on or you will bend valves on first start. Let me know if you have any questions
onesickstang01 is offline
Closed Thread
08:59 AM
