gear ratio - Mustang Evolution
Old 07-04-2012, 11:13 AM   #1
meano1's Avatar
gear ratio
Ok, so I followed some advice on this forum to determine rear end gear ratio. I jacked up rear end and marked with a paint marker the inside of wheel and also marked a spot on driveshaft. I am getting about 3 and 1/8 turns to every 1 wheel revolution. Stock, the car came with 2.73 gears. So any idea what gears I have?
1998 Mustang Gt, MSD coils, Ford Racing lowering springs, KYB shocks, caster camber plates, Flow Tech exhaust, K&N CAI, auto trans with shift kit, Jet Performance module, full length sub frame connectors, Redline Tuning hood struts. Oh yea, forgot to mention the Plasti Dip stripes.
meano1 is offline   Reply With Quote
Old 07-04-2012, 11:59 AM   #2
Mile high JDF's Avatar
3.08s?
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 07-04-2012, 12:03 PM   #3
TopgearGT's Avatar
What is your rpm to speed ratio... if you go onto AM's website and go to there gears, they have a speed chart that tells you your rpm's at different speeds for all the different gear ratios. Check your rpm when driving at around 70 and compare it to there charts. That might give you a general idea!
http://www.mustangevolution.com/forum/users/25023-albums2837-17413.jpg
CSVT and 02 GT!
TopgearGT is offline   Reply With Quote
Old 07-04-2012, 12:03 PM   #4
deadsp0t's Avatar
Originally Posted by JDF
3.08s?
Sounds right, can't figure why someone would go through the work and cost? Possibly 3.27's..
Op have you looked for or at the tag on the diff cover for the the ratio? Generally when they've been changed the tag gets removed.
That's unimpressive
Old 07-04-2012, 12:11 PM   #5
That was my thought.
Old 07-04-2012, 01:01 PM   #6
meano1's Avatar
I think the tag is still there. I'm going to go to AM website and look for their speed/rpm chart and double check. They could be stock 2.73's though.
Old 07-04-2012, 01:19 PM   #7
BigB227's Avatar
My 03 Gt came stock with the 3.27s
BigB227 is offline   Reply With Quote
Old 07-04-2012, 01:27 PM   #8
meano1's Avatar
Ok, just went driving and at 70mph with O/D off I was running about 2700 rpm. At 60 mph with O/D on I was turning 1700 rpm.
Old 07-05-2012, 12:00 AM   #9
Re: gear ratio
They are 2:73 rear axle if it is stock and thats what was a friend of mins 98 and my 97 when we changed gears. The cobras are the ones that had the 3:27 This link even proves it
Used 1998 Ford Mustang GT Coupe Handling Specs - 1998 Ford Mustang GT Coupe Handling Specifications - Motor Trend Magazine
southernstang00 is offline   Reply With Quote
Old 07-05-2012, 03:52 AM   #10
deadsp0t's Avatar
My 95 has 3.27's.. Point is there are options..
That's unimpressive
Old 07-05-2012, 04:20 AM   #11
Re: gear ratio
I never said there wasnt, I know that had 3:27's as a option. I over looked that he stated it was a automatic. With it being a automatic I would say 3:08 then because before i changed mine in my 2000 GT I was getting little bit higher RPM's and it had 3:27's . My 97 and a friend of mine's 98 was manuals and they have 2:73 in them.
Meano, here is a site that will tell you everything you want to know about your car..
http://poisnus.com/files/mustanginfo/mustang_info1.html
Old 07-05-2012, 07:46 AM   #12
MustangGT02's Avatar
Re: gear ratio
Use this, its been accurate for my auto so far. PaladinMicro
Go to the Calculatiors tab then click How Fast/Each Gear
MustangGT02 is offline   Reply With Quote
Old 07-05-2012, 08:33 PM   #13
meano1's Avatar
Thanks everyone for their help. I love this forum!!
05:26 PM
