I have a few codes... - Mustang Evolution
Old 07-05-2012, 06:53 AM   #1
I have a few codes to take care of before I get my car inspected... They are P0117, P1117, P1401, and P1443. Has anyone had these codes before, and can tell me what you did to fix them?
Thanks Everyone!
Oh and mods are BBK LTs, BBK o/r H, Catback, Underdrives, CAI, SCT canned tune... and some other goodies
98GT- CAI,Steeda Tri-Ax,o/r H, Underdrives, toon, more to come!
94V6- CAI, true duals, underdrives. the playtoy
i973eat1 is offline   Reply With Quote
Old 07-05-2012, 06:49 PM   #2
1996mustang's Avatar
Re: I have a few codes...
P0117 Engine Coolant Temperature Circuit Low
P1117 Engine Coolant Temperature Sensor Intermittent
P1401 Differential Pressure Feedback Electronic Sensor circuit High Voltage
P1443 Evaporative Emission Control System - Vacuum System - Purge Control Solenoid or Purge Control Valve Fault
Old 07-05-2012, 07:37 PM   #3
Thanks, but I already knew what they were, What I NEED to know is how to fix em now. thanks!
Old 07-08-2012, 05:25 PM   #4
Bump... I replaced the Coolant temp sensors, and fixed one problem, (P0117, P1117) now I have those others to fix...
Old 07-08-2012, 10:05 PM   #5
Ok first off sorry for the late response. Been busy with work and im glad to hear u fixed one problem. As for your other 2 sorry for the explanation....the differential pressure is referring to the silver box which should lie by the driver side firewall. It gets 2 vaccum lines coming from the egr tube. High input usually means might be disconnected so check to see if that's the case. As for your evap one i would check the vacuum lines goin to both purge valve and the other one i think surge valve. Im not sure what motor u have so may be different locations im goin off the top if ny mind visualizing my 4.6 so if i knew what motor id be able to all data the answers better
Old 07-10-2012, 06:34 AM   #6
Thats alright, It is a SOHC 4.6 GT motor in the car. I know what box you are talking about though, I think. I will check those though also. Thank you!
Old 07-10-2012, 07:35 PM   #7
Ok i have a pic with the box by it pardon the quality
Old 07-10-2012, 07:36 PM   #8
Top right if the one closest to firewall
Old 07-10-2012, 08:12 PM   #9
Thank you!
10:55 AM
