07-05-2012, 12:17 PM
#1 | | Registered User
| Best mustang stance
What is the best suspension setup to go with that has a great low stance that I want for looks. I'm not looking in to racing it or anything so just for looks? It's also a daily driver!
07-05-2012, 12:55 PM
#2 | | Registered User
Ford racing spring
07-05-2012, 01:12 PM
#3 | | Registered User
I have eiback sport line and kyb ago shocks great stance great performance nice and tight no body roll 2" drop in front and 1 1/2 in back with 17" svt rims
07-05-2012, 01:34 PM
#4 | | Registered User
Get coils so you can adjust it however u want
__________________  )02 Gt, Founder of WE2G
07-05-2012, 01:51 PM
#5 | | Registered User
If you get the h&r sport springs will I have to get the shocks and struts right away or when do I have to have shocks and struts? Cause I wanna go with h&r sports and then camber bolts but I don't have the funds for shocks and struts so when do I need them or do I need them?
07-05-2012, 01:52 PM
#6 | | Registered User
Coil overs
07-05-2012, 02:04 PM
#7 | | Registered User
| Quote: |
07-05-2012, 02:09 PM
#8 | | Registered User
| Quote: |
Originally Posted by M97cobra I have eiback sport line and kyb ago shocks great stance great performance nice and tight no body roll 2" drop in front and 1 1/2 in back with 17" svt rims | +1
07-05-2012, 02:23 PM
#9 | | Terminator Owner
| Re: Best mustang stance
the rear usually .5 inches higher than the front works best. I like mine at 26.0 ground/fender front and 26.5 rear (2003 model) Any more would be to low. Even now I am a bit to low for a daily driver. Once you get it lowered you need the rear rims to stick out more else it looks odd. Spacers can help there, but dont go to far or you will cut your tire on your fender lip (or have to roll them up to keep from doing that)
__________________ 2003 Cobra Vert (Redfire) #3938 of 5082 @ 05/27/2003
472rwhp/493rwtq - Modification List - Dyno Sheet 2012 Mustang 3.7L M6 (Kona Blue) 2011 Ford Edge Sport (Red Metallic) |
07-05-2012, 07:23 PM
#10 | | Registered User
| Quote: |
Originally Posted by M97cobra I have eiback sport line and kyb ago shocks great stance great performance nice and tight no body roll 2" drop in front and 1 1/2 in back with 17" svt rims | True, but am still fighting a 1 piece headlight aiming issue cuz of it. Only stock split works
---Las97GT
07-05-2012, 07:36 PM
#11 | | Registered User
| Quote: |
Originally Posted by RUNNWLD If you get the h&r sport springs will I have to get the shocks and struts right away or when do I have to have shocks and struts? Cause I wanna go with h&r sports and then camber bolts but I don't have the funds for shocks and struts so when do I need them or do I need them? | Good question! I was wondering the same thing! Bump so someone will answer this question!!!
CSVT and 02 GT!
07-05-2012, 07:44 PM
#12 | | Moderator Emeritus
It's recommended for sure.
That's unimpressive
07-05-2012, 07:59 PM
#13 | | Registered User
you may not have to have them right away but you will eventually, your already gonna have the struts out doing the springs. You will just be doing double work. Also i vote for H&r SS!!
07-05-2012, 09:27 PM
#14 | | Registered User
Coilovers.....
07-05-2012, 09:29 PM
#15 | | Registered User
| Quote: |
Originally Posted by Mzilla Coil overs | What coilovers do you have?
07-05-2012, 10:11 PM
#16 | | Registered User
So If I just got the springs and camber bolts. How long tell I should get the shocks and struts?
07-06-2012, 04:55 AM
#17 | | Registered User
| Quote: |
Originally Posted by bobsurvives
What coilovers do you have? | UPR/QA1 coilovers with bilstein struts, UPR caster-camber plates, UPR bump steer kit, Steeda offset rack bushings, Steeda sway bars. The rear has Steeda sport springs with Tokico Illumina 5 way adjustable shocks and UPR upper and lower control arms.
07-06-2012, 05:05 AM
#18 | | Registered User
| Re: Best mustang stance Quote:
Originally Posted by M97cobra I have eiback sport line and kyb ago shocks great stance great performance nice and tight no body roll 2" drop in front and 1 1/2 in back with 17" svt rims | I vote for this as well, I have this setup on my 00 GT and its low enough for me and just the right height to keep from hitting my LT on bumps.
How long before you would have to change them? Depends on how worn out they are now I would think.
Just a FYI whatever spring you get make sure you get new insulators with them, I made that mistake and had to do double work.
I agree with doing it all at one time, save the money until you get the springs and shocks and do it all at one time so you dont have to double work yourself. ---------- Post added at 06:05 AM ---------- Previous post was at 06:04 AM ---------- Quote:
Originally Posted by Mzilla UPR/QA1 coilovers with bilstein struts, UPR caster-camber plates, UPR bump steer kit, Steeda offset rack bushings, Steeda sway bars. . | I know this might be a dumb question but what does the offset rack bushings do or help?
07-06-2012, 05:44 AM
#19 | | Registered User
My pics are hr and tokico.
All my friends say this stance really looks the best.
Never have issue with speed bumps or clearance.
And it handles excellent.
07-06-2012, 06:26 AM
#20 | | Registered User
| Quote: |
I know this might be a dumb question but what does the offset rack bushings do or help? | The rack bushing lower the rack to help with the suspension geometry. When ever you lower a car really aggressively it changes tie rod to knuckle geometry. I also highly recommend a bump steer kit also though with coil overs you do not get as much bump steer as you do with lowering springs. The bumper steer kit realigns the tie rid ends properly
07-06-2012, 06:33 AM
#21 | | Registered User
Originally Posted by Mzilla The rack bushing lower the rack to help with the suspension geometry. When ever you lower a car really aggressively it changes tie rod to knuckle geometry. I also highly recommend a bump steer kit also though with coil overs you do not get as much bump steer as you do with lowering springs. The bumper steer kit realigns the tie rid ends properly | That I did not know im glad you shared that with me I might have to look into getting those. Would you say a 2 inches front and rear(alsome) would be considered aggressively for these bushing to be needed?
07-06-2012, 06:54 AM
#22 | | Registered User
Yes it will help dramatically
07-06-2012, 06:56 AM
#23 | | Registered User
hmm where can you get these from?
07-06-2012, 07:04 AM
#24 | | Terminator Owner
coil overs can give major headaches and once set you probaly wont adjust further, just fyi
07-06-2012, 09:06 AM
#25 | | Registered User
| Quote: |
Originally Posted by SpectorV coil overs can give major headaches and once set you probaly wont adjust further, just fyi | Once I had my ride height set where I liked it i never adjusted it again. The coil overs simply ride better and handle better due to better suspension geometry
07-06-2012, 12:19 PM
#26 | | Registered User
| Quote: |
Once I had my ride height set where I liked it i never adjusted it again. The coil overs simply ride better and handle better due to better suspension geometry | Really?? Lol I adjust em every like 2 weeks. Like someways I adjust my coils at like 2 inches and when we go on cruises I slam it to 3 and a lil more but I have to drive super careful
07-06-2012, 12:40 PM
#27 | | Registered User
| Quote: |
UPR/QA1 coilovers with bilstein struts, UPR caster-camber plates, UPR bump steer kit, Steeda offset rack bushings, Steeda sway bars. The rear has Steeda sport springs with Tokico Illumina 5 way adjustable shocks and UPR upper and lower control arms. | The Steeda sport springs gave you that much drop in the rear?
07-06-2012, 01:55 PM
#28 | | Registered User
Yes but also I have 18x10 on the rear with 305-35-18 drag radials
07-06-2012, 02:06 PM
#29 | | Registered User
| Quote: |
Originally Posted by Mzilla Yes but also I have 18x10 on the rear with 305-35-18 drag radials | Yeah, I have 18x10's in the rear, with 295-35-18 hankook radials
07-06-2012, 06:39 PM
#30 | | Registered User
I love MZilla's and SpectorV's stance
07-09-2012, 07:47 PM
#31 | | Registered User
08-19-2012, 01:09 AM
#32 | | Registered User
Sense I got the h&r super sport springs but the wheel gap in the back is a little higher than I want then how would I make that a lil lower?
08-19-2012, 01:18 AM
#33 | | Registered User
| Quote: |
Originally Posted by RUNNWLD Sense I got the h&r super sport springs but the wheel gap in the back is a little higher than I want then how would I make that a lil lower? | If you just installed them, they might still settle in and end up lowering on their own. Or you can remove your isolators if you kept them in. Otherwise you may need adjustable control arms to lower the rear some more.
Proud owner of Bullitt #1075
08-19-2012, 01:34 AM
#34 | | Registered User
If you remove your isolators will that ruin anything? Or risk anything cause are you supposed to have them on?
08-19-2012, 03:45 AM
#35 | | Registered User
| Quote: |
Originally Posted by RUNNWLD If you remove your isolators will that ruin anything? Or risk anything cause are you supposed to have them on? | No you won't ruin anything, removing the iso's will give you about another 1/2" drop just wrap the ends with electrical tape to prevent the metal on metal contact, if you don't you will have a grinding sound , some guys like to use grease on the spring but I prefer the tape.
