Need quick help!! Transmission - Mustang Evolution
Old 07-05-2012, 07:02 PM   #1
silver98mustang's Avatar
As I'm sure a lot of you guys are aware of, mustang week is in 11 days!!! I was getting s excited i decided to pull out my crappy automate transmission and swap it to a manual. So i don't have any of the parts needed for the swap, but i have everything removed from my car. I can get a TR-3560 from an 01 cobra for 850 bucks (that includes wiring harness, driveshaft, steeda shifter, clutch pedal assembly, and the clutch fork, and the crossmember). Now i know the 3560 will bolt up with the crossmember relocation brackets from D&D performance. But my question is, what clutch/flywheel do i need to order. My 98GT has a 6-bolt flywheel and the 01 cobra has an 8-bolt. With that being said i can only run a 98GT 6-bolt flywheel, so should i get a clutch for a 98, or the clutch for the 01. And also does anyone know if i will need the computer?
silver98mustang is offline   Reply With Quote
Old 07-05-2012, 07:16 PM   #2
LAS97GT's Avatar
Can't help in this category but see you at mustang week
---Las97GT
Old 07-05-2012, 07:39 PM   #3
deadsp0t's Avatar
Call D&D to be sure you get the most accurate info and do not miss mustang week.
That's unimpressive
Old 07-05-2012, 08:36 PM   #4
RRQuick's Avatar
Re: Need quick help!! Transmission
When is Mustang week, and where is it located????
RRQuick is offline   Reply With Quote
Old 07-05-2012, 10:16 PM   #5
Matticus's Avatar
I thought the cobras had like a T-56 or something because the manual GT's after 01 have the TR-3650
Matticus is offline   Reply With Quote
« gear ratio | Radio »
03:55 PM
