TB&plenum. - Mustang Evolution
Old 07-06-2012, 12:55 PM   #1
1lowGT's Avatar
TB&plenum.
What the best throttle body and plenum combo and size is best for slightly modded GT
CAI and cat back exhaust
Future: full exhaust gears and tune
Old 07-06-2012, 12:57 PM   #2
Re: TB&plenum.
I got the trick flow plenium and ford racing TB 75mm and I love it...
southernstang00 is offline   Reply With Quote
Old 07-06-2012, 01:30 PM   #3
Rexxx73's Avatar
Have trick flow with k&n cold air intake and is very responsive
Rexxx73 is offline   Reply With Quote
Old 07-06-2012, 01:32 PM   #4
1lowGT's Avatar
What's all your mods
Old 07-06-2012, 01:39 PM   #5
Rexxx73's Avatar
So far
---------- Post added at 02:39 PM ---------- Previous post was at 02:38 PM ----------
2000 gt (cobra clone) k&n cold air intake, trick flow intake and throttle body, 4.6 npi block w/ pi top end, full magnaflow exhaust w/ cat delete, hotchkis suspension, cobra calipers w/ slotted rotors, 18 in svt rims
Old 07-06-2012, 01:51 PM   #6
1lowGT's Avatar
Nice Nice
Old 07-06-2012, 02:03 PM   #7
Re: TB&plenum.
what I said above along with trick flow heads CNC ported, bigges energy comp cam for modular engines, dyno tune, all the bolts ons pretty much other then the intake. 2800 stall....shortier rods as well ordering charger here soon
Old 07-06-2012, 03:01 PM   #8
AmericanMuscle.com
Sponsor
AMDanBailer's Avatar
Re: TB&plenum.
1lowGT,
I don't think you can wrong with any of the TB & Plenum set ups. As far as throttle body size goes, I wouldn't go any bigger then a 70MM. Anything bigger then that is just to much air the ECU can't compensate & won't make any more power.
I hope this helps, if you have any further questions Our Mustang Experts are here Monday-Friday from 9AM-9PM EST and Saturdays from 9AM-5:30PM EST. If you want to hit them up, their number is 866.727.1266. I can also have one of them call you directly.
- Dan
Old 07-06-2012, 03:05 PM   #9
I have a 70MM an throttle response is great
Ryan7racin is offline   Reply With Quote
Old 07-06-2012, 03:11 PM   #10
Re: TB&plenum.
Originally Posted by AMDanBailer View Post
1lowGT,
- Dan
Even with the setup I have and dyno tuned?
Old 07-06-2012, 07:36 PM   #11
CodyNelson's Avatar
Region: West Virgina
Re: TB&plenum.
I agree with Dan but for a different reason. Dont go any bigger than 70mm. Its not just about how much air you can get in, its also about velocity. The motor can only suck so much air. And if you make the pipe bigger all you do is slow the air down. Without velocity the motor will lose low end torque
Old 07-06-2012, 10:33 PM   #12
jjsg09's Avatar
I have the Accufab TB and Plenum. VERY HAPPY!!!!
Old 07-06-2012, 11:08 PM   #13
1996mustang's Avatar
80 mm bbk throttle intake
Old 07-07-2012, 10:26 AM   #14
1lowGT's Avatar
What's stock size
Old 07-07-2012, 10:30 AM   #15
Matticus's Avatar
I think it's like 56mm. Someone correct me if that's not right.
Matticus is offline   Reply With Quote
Old 07-07-2012, 12:03 PM   #16
1lowGT's Avatar
Just making sure. Anyone have stack racing 70mm tb and stack raving plenum? Or heard anything from them?
08:28 AM
