4.6 npi block with pi heads - Mustang Evolution
Old 07-06-2012, 12:27 PM   #1
Rexxx73's Avatar
If anyone has tried to find if this will work the answer is yes. And not only that I used a Romeo block from crown vic po int car and my Windsor top end. Did the swap due to bad rod bearing. All I needed other then gasket kit was Romeo 6 bolt pattern flywheel since Windsor block had 8 bolt crank pattern
Rexxx73 is offline   Reply With Quote
Old 07-06-2012, 08:09 PM   #2
Are you refereeing to a PI swap ? Cause that's a npi block with PI heads
96gt014.6 is offline   Reply With Quote
Old 07-06-2012, 09:04 PM   #3
Mile high JDF's Avatar
Yep that's what he's referring to.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 07-06-2012, 09:07 PM   #4
Rm360's Avatar
Bubble busters!!! Lmfao!!!
Old 07-06-2012, 09:11 PM   #5
I figured it was lol
04:21 AM
