bump-steer - Mustang Evolution
Old 07-06-2012, 03:29 PM   #1
bump-steer
What is it and what does it exact do? Preventing this help with cornering?
southernstang00 is offline   Reply With Quote
Old 07-06-2012, 06:25 PM   #2
Mile high JDF's Avatar
Bump steer is when you go over a bump and the car attempts to turn, the steering wheel will jerk to one side or another.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 07-06-2012, 07:05 PM   #3
bobsurvives's Avatar
So if I get the Steeda bumpsteer kit.... It will eliminate bump steer?
bobsurvives is offline   Reply With Quote
Old 07-06-2012, 07:27 PM   #4
CrookedHalos's Avatar
I thought bump steer is when you go over a bump and it makes your rear jump to one side or the other. From what someone told me when I asked about the steering wheel turning, it wouldn't help that. But I don't own one so I don't really know either way
CrookedHalos is offline   Reply With Quote
Old 07-06-2012, 07:41 PM   #5
deadsp0t's Avatar
When you lower your car the steering geometry changes.. The bump steer kit will eliminate the 'sloop' in your steering wheel and allow your car to be aligned properly. This is an issue when you drop 2" and more. Kit should be used with CC plates and is a must to use x2 ball joints.
That's unimpressive
Old 07-06-2012, 07:45 PM   #6
Yes, I believe MZilla explained it in another thread, but the reason it bump steers is because the steering knuckle and the steering arm travel in different arcs after you lower a car. The bump steer kit relocates the steering arm to travel back in line with the steering knuckle.
---------- Post added at 12:45 AM ---------- Previous post was at 12:44 AM ----------
Damn you beat me to it.
^ that's the simple explanation
Old 07-07-2012, 02:31 AM   #7
Re: bump-steer
Hmm, did not know that I really havent felt any difference in the steering since I lowered but I think will def look into the bump-steer kit and ball joints. CC plates I know you have to get a alignment after they are installed, can any shop that does alignments do the alignment? Or do I need to take it to a speed shop of some sort since its not a stock app?
Old 07-07-2012, 03:37 AM   #8
deadsp0t's Avatar
Any reputable alignment shop should be able to handle it!
That's unimpressive
Old 07-07-2012, 08:42 AM   #9
Re: bump-steer
Alrighty thanks glad you told me that...
Old 07-07-2012, 09:42 AM   #10
Re: bump-steer
I was looking on AM site and I see the Steeda x-2 ball joints and one set does both driver and pass side. So that means I have to buy two sets for both the upper and lower?
Old 07-07-2012, 04:34 PM   #11
deadsp0t's Avatar
This link is too a thread on Steeda's forum to a thread I posted.
http://www.steedaforums.com/topic/96...3441#entry3441
That's unimpressive
Old 07-07-2012, 11:50 PM   #12
Re: bump-steer
X2's for 1995 GT - 1994-2004 Mustang Discussion - Steeda Forums
iight thanks I got your PM im about to go there right now thanks man
Old 07-08-2012, 03:15 AM   #13
deadsp0t's Avatar
if your questions are not answered you can create an account and ask their reps.. Very friendly and knowledgable about their products..!
That's unimpressive
Old 07-08-2012, 03:45 AM   #14
Re: bump-steer
Okie dokie thanks for the help man.
---------- Post added at 03:45 AM ---------- Previous post was at 03:41 AM ----------
I looked at the thread, did you end up getting the x2 or 4 kit?
Old 07-08-2012, 03:52 AM   #15
deadsp0t's Avatar
Haven't done either. My immediate issue was my tie-rods needed to be greased.
After talking to FastLane(local speed/Mustang shop) I plan on doing the level 4 upgrade(includes X2's I believe) and doing it all at one time.. Labor for the entire install will approach 1k if I remember correctly.
That's unimpressive
Old 07-08-2012, 04:33 AM   #16
Re: bump-steer
aw okie gotcha whats a 4 upgrade contain?....Im def getting the X2 ball joints, bump-steer, CC plates after I through the supercharger on. I have alot of work I have to do on both cars with all of the parts I have ordered sitting in my room.
I'm glad you showed me that forum cuz I was checking out their parts and they have the supercharger pulley I was looking for.
09:15 AM
