Slave cylinder - Mustang Evolution
Go Back   Mustang Evolution > 1979-2014 Mustang GT > 1996-2004 Mustang GT
Old 07-07-2012, 07:11 PM   #1
Kotty4643's Avatar
Kotty4643 is unknown around these parts
Slave cylinder
I have a 96 mustang gt 4.6 v8 and I'm going to replace the clutch because it went out on the person I bought it from but I don't have tones of money and I called auto zone oriley and advanced none carry it for my car they say dealer part but I was wandering if any one new around how much one cost and if I can buy it online and were to try and save money????
Kotty4643 is offline   Reply With Quote
Old 07-07-2012, 07:15 PM   #2
deadsp0t's Avatar
deadsp0t is unknown around these parts
Because it uses a cable
That's unimpressive
Old 07-07-2012, 08:13 PM   #3
JDF
JDF's Avatar
JDF is unknown around these parts
Yeah you just need the clutch, pilot bearing, throw out bearing, and hopefully no flywheel
2000 GT-
Engine: K&N cold air intake, Bassani offroad x, Magnaflow catback, Bama 91 octane race tune, 3.55 gears dyno'd at 233whp 272wtq before exhaust
Suspension: IRS swap with stock cut 03 Cobra springs
Brakes: Front and rear brakes from an 03 Cobra with EBC Yellowstuff pads
JDF is offline   Reply With Quote
Old 07-07-2012, 08:51 PM   #4
Kotty4643's Avatar
The flywheel is fine I know. That so ur saying I don't need to replace the slave cylinder? ?
Old 07-07-2012, 08:53 PM   #5
Senior Member
dreamstang is unknown around these parts
they are saying there isnt one. idk for sure but these guys do. but a slave cylinder is for a hydraulic clutch and yours is cable.
Old 07-07-2012, 08:54 PM   #6
JDF
JDF's Avatar
You don't have a slave cylinder, those are for hydraulic setups. Your mustang have a clutch cable setup, which is what deadsp0t was referring to.
2000 GT-
Old 07-07-2012, 08:55 PM   #7
deadsp0t's Avatar
^this exactly!
That's unimpressive
Old 07-07-2012, 08:56 PM   #8
Kotty4643's Avatar
And the trans is a t5
Old 07-07-2012, 08:57 PM   #9
JDF
JDF's Avatar
What he said^
2000 GT-
Old 07-07-2012, 09:03 PM   #10
Kotty4643's Avatar
Originally Posted by deadsp0t
^this exactly!
Thank u so much u just saved me alot of serching
Old 07-07-2012, 09:07 PM   #11
JDF
JDF's Avatar
No problem. One thing to check out is your clutch quadrant, those have been known to go bad. How any miles are on your car?
2000 GT-
Old 07-07-2012, 09:33 PM   #12
Kotty4643's Avatar
Says 119k but the sensor went bad on the trans from there person I bought it from that registers speed and I have not even started looking for that I I'm sure the millage is closer to 200k and I do know the trans went from t5 to a Trimic tko back to a t5 with the guy that had it before my friend and he was the second owner and I'm the 4 th owner of the car I know for sure so my friend was the 3 rd owner and I'm the 4 th yep I m positive on that
Old 07-07-2012, 09:34 PM   #13
Senior Member
You lost me 3 owners ago. Lol
Old 07-07-2012, 09:38 PM   #14
Kotty4643's Avatar
Lol one of the prior owners swapped the trans to a trimic tko then put a t5 back and never replaced the speed sensor so it won't register miles or speed it says 119000 on the dash but its probably more like 200000 and what is a clutch quadrant?
Old 07-07-2012, 09:49 PM   #15
JDF
JDF's Avatar
The clutch quadrant is the self adjuster on our cars, basically as our clutches wear out the quadrant adjusts itself to keep the area that it catches the same. If you look under the clutch pedal st where it hooks up, there should be what looks like a white half circle where your clutch attaches to the firewall. Those have a tendency to go out especially if you put a stiff aftermarket clutch in
2000 GT-
Old 07-07-2012, 10:02 PM   #16
Kotty4643's Avatar
Ill check that do I just need yo replace the white thing or what
---------- Post added at 10:00 PM ---------- Previous post was at 10:00 PM ----------
And I'm just putting in a n OEM clutch
---------- Post added at 10:02 PM ---------- Previous post was at 10:00 PM ----------
From auto zone my friend bought it before I bought the car I will eventually put a stage 2 in it when my money is looking better
Old 07-07-2012, 10:02 PM   #17
JDF
JDF's Avatar
I honestly don't know, I have never replaced one before. A lot of people just go with an firewall adjuster kit that eliminates the quadrant.
2000 GT-
Old 07-07-2012, 10:05 PM   #18
Kotty4643's Avatar
Its it a clutch peddle bushing??? That's all I found on auto zones android app
Old 07-07-2012, 10:05 PM   #19
JDF
JDF's Avatar
Ok that's a good ideas
2000 GT-
Old 07-08-2012, 02:17 AM   #20
deadsp0t's Avatar
96 has a T45 btw..
That's unimpressive
Old 07-08-2012, 02:20 AM   #21
Kotty4643's Avatar
I was told it was a t5 Idk yet ill find out for sure soon lol
Old 07-08-2012, 02:23 AM   #22
deadsp0t's Avatar
I guess it's possible.. If I had to wager sight unseen, my money would be on T45
Be sure to update! I'm curious now lol
That's unimpressive
Old 07-08-2012, 02:30 AM   #23
Kotty4643's Avatar
Will do man
Old 07-10-2012, 05:05 AM   #24
LAS97GT's Avatar
LAS97GT is unknown around these parts
Pulls the fly wheel and get it turned on a lathe.
---------- Post added at 06:54 AM ---------- Previous post was at 06:52 AM ----------
There is no slave cylinder.
---------- Post added at 06:57 AM ---------- Previous post was at 06:54 AM ----------
Never mind, that was mentioned already.
---------- Post added at 07:05 AM ---------- Previous post was at 06:57 AM ----------
Do you have an engine oil leak at the tranny/engine area? With the mileage you have, it's not a bad idea to replace the rear crankshaft seal too. Remember there's the actual seal and a spacer, you can reuse the spacer/seal if you get it out clean.
---Las97GT
Old 07-10-2012, 11:58 AM   #25
95v686gt's Avatar
95v686gt is unknown around these parts
There's a place outside Louisville ky called Kentucky clutch. They give damn good deals on clutches. Look them up. Might be able to get a performance clutch cheap. Just a little FYI for everyone
1995 V6 Mustang= Divorced Duals, Flowmaster 2 chambers, NO CATS, Raxiom Halo Projector headlights, Smoked Tails, 17 inch Bullitt Wheels
1997 Mustang GT: 4.6L DOHC http://www.mustangevolution.com/forum/f280/t305270/
1986 Mustang GT= Built 302 SOLD
95v686gt is offline   Reply With Quote
Old 07-10-2012, 04:28 PM   #26
LAS97GT's Avatar
96 has a T45 btw..
+1
---------- Post added at 06:28 PM ---------- Previous post was at 06:19 PM ----------
After you grease up the fork, if it falls back on it's own, replace it. If you don't have the dough, no bother, the retainer will keep it up there, but all metal retainers, copper looking do-hickies, must be on the thing. I love this. I drop my tranny just for fun.
---Las97GT
Old 07-10-2012, 07:29 PM   #27
Vegas97gt's Avatar
Vegas97gt is unknown around these parts
Yeah its best to change what might go out even if money is tight cuz you don't want her giving out on you and costing you more money later.
Vegas97gt is offline   Reply With Quote
Old 08-02-2012, 10:37 PM   #28
Kotty4643's Avatar
Re: Slave cylinder
Originally Posted by deadsp0t View Post
96 has a T45 btw..
yea stock mine has been changed to a t5 though and now i got more problems with the transmission after i put the clutch in a week ago and drove it for a week now the car is stuck in reverse and will not go back in neutral it only goes in reverse and another high gear my friend tried to force it out of reverse when i went to the bathroom now when its in reverse it looks like it is in 5th what do i do
05:17 PM
