Engine build - Mustang Evolution
Old 07-07-2012, 10:29 PM   #1
chickengeorge's Avatar
Engine build
I want to f/i my car someday but dont want to risk blowing up my engine. Ive been looking into forged internal kits on stage3motorsports but i just dont understand where to start lol
4.5 dished pistons?
10.5 ?
What do these numbers mean
Bigger the number the better?
Dished pistons?
Flat top?
Whats the difference?
Someone care to educate a noob about this??
chickengeorge is offline   Reply With Quote
Old 07-07-2012, 10:38 PM   #2
Mile high JDF's Avatar
I don't know a lot but here goes:
The 4.5 I don't know, depends on if that's dished or domes
The 10.5 is compression ratio. If you want to go FI then you want something much lower, usually 8.5 or or 9:1 is what most people go with.
Dished, flat top, and domed pistons are the type of piston. Imagine concave, flat, and convex type if that puts it similar.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 07-07-2012, 11:05 PM   #3
http://www.stage3motorsports.com/cat...ine_internals/
This is what im looking at. Thanks for answering though
Old 07-07-2012, 11:10 PM   #4
Ok, so the numbers it lists are how much of a dish your are getting. The bigger the number, the bigger the dish, the lower your compression ratio.
Old 07-07-2012, 11:23 PM   #5
Mmmmmm i see
What about compatibilty? What do i need to change to accommodate these changes like heads? Does it matter if i just throw this into a stock block and cylinder heads? Or is this where the term "bore" comes into use hahahaha i feel so hopeless
Old 07-07-2012, 11:31 PM   #6
Mmmmmm i see
Your bore is how wide your cylinders are. Most people when they build an engine will "refresh" the block, basically cut a wire hole in the block. When you do that you need to order a piston that's gas been sized up to that new bore. You don't need new heads but it definitely helps to get at least a port and polish job on the stock heads. I would do cams also.
Old 07-07-2012, 11:43 PM   #7
Okok
Im certainly getting the idea now
Old 07-07-2012, 11:45 PM   #8
Okok
Sweet
12:59 PM
