Mustang serpentine belt - Mustang Evolution
Old 07-08-2012, 08:32 PM   #1
98RedGT's Avatar
I have a 98 GT my problem is my serpentine belt. Whenever it's fully on the AC pully it makes a loud squeaking sound and after 20 seconds adjusts itself a little off. Check out the picture. Should I be worried?
ROOM FOR IMPROVEMENT
98RedGT is offline   Reply With Quote
Old 07-08-2012, 11:50 PM   #2
Re: Mustang serpentine belt
Yeah I would be worried because eventually it might start to shread the belt. This is just a wild guess but if all other pulleys look good and arent wobbling and its line I say the AC clutch/pulley might be bad.
When the ac is off what does it do? Does it stay on the ac pulley correctly?
southernstang00 is offline   Reply With Quote
Old 07-09-2012, 12:02 AM   #3
98RedGT's Avatar
that was with it off lol, thats why Im like wtfff
Old 07-09-2012, 01:53 AM   #4
A good chance the a/c clutch is bad....maybe there is too much play somewhere in there that when you engage and disengage the A/c the pulley moves too much and knocks it out of line and thats they the belt is on the edge.
I dont think the compressor itself is bad, just the clutch. You might be able to just buy the clutch but when I worked at autozone and the dealership all I saw was you had to buy the whole thing. Check other things before going buying anything...
I not saying this is it just trying to give you an area to check/look at because when you turn the a/c on you hear a noise from it right? Check and make sure there is good tension on the belt then check the belt tensioner as well.
Old 07-09-2012, 04:47 AM   #5
LAS97GT's Avatar
Check the tensioner too. It should be rock steady, not hopping up and down under torque, too much will cause belt shift, and belt slippage. It's 2 o' clock from the AC pulley.
---Las97GT
Old 07-09-2012, 08:00 AM   #6
98RedGT's Avatar
No the AC wasn't on when it made it.
Old 07-09-2012, 10:38 AM   #7
98RedGT's Avatar
And the belt is lined up perfect on the other pulleys, today I tried to re-adjust several times and everytime I started the car there was a squeak for about 2 seconds then it was back like that, it drives and runs fine but when I am at idle it jumps between 500-1000 RPMS
Old 07-09-2012, 10:22 PM   #8
So the belt tensioner itself was okie and doesnt have any play?
I want to say its something with the ac pulley causing the belt to jump...but thats my opinion.
Old 07-10-2012, 07:44 AM   #9
98RedGT's Avatar
I replaced the tensioner because it was under warranty and it's fixed lol. Thanks guys!
Old 07-10-2012, 07:48 AM   #10
Thats good glad to hear its fixed
Old 07-10-2012, 04:33 PM   #11
LAS97GT's Avatar
Same here. Glad that problem is over too. Enjoy! Come back when you have another prob.
---Las97GT
09:23 AM
